| Winches https://mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=697 |
| Author: | marsh bandit [ Tue Feb 17, 2009 10:59 am ] |
| Post subject: | Winches |
Can't figure out how to get to the old site... What kinda winches y'all using? |
| Author: | Gatorpoint [ Tue Feb 17, 2009 5:49 pm ] |
| Post subject: | Re: Winches |
Warn 2.5 XT |
| Author: | tongthrower [ Tue Feb 17, 2009 7:19 pm ] |
| Author: | blaze [ Tue Feb 17, 2009 7:51 pm ] |
How are yall mounting them to the boat? |
| Author: | Duck Diggler [ Wed Feb 18, 2009 5:34 am ] |
I mounted mine on my trolling motor bracket. It was the only place I knew I could mount it that had room for the winch to work and a thick surface. 2 quarter-twenty bolts and she is good to go. |
| Author: | coastal [ Mon Mar 16, 2009 1:58 pm ] |
Thinking of ordering this one...Yea or Na?????? http://www.gorillawinches.com/atv-winch ... ckage.html |
| Author: | tongthrower [ Mon Mar 16, 2009 2:07 pm ] |
Coastal, that looks a lot like a warn... looks like they even use similar nomenclature... might be a good buy. |
| Author: | stanco [ Mon Mar 16, 2009 2:39 pm ] |
lot of the mudders over at highlifter.com use and like them. |
| Author: | willett [ Mon Mar 16, 2009 4:37 pm ] |
coastal glad you found that deal! i'm fixin to order me one also ordering a roller fairlead and wireless remote kit if ya get a winch of any kind make sure you get the roller fairlead for it...the ones they come with even with syn. rope will mess the rope up its under the "Winch Maintenance" button on that site |
| Author: | white1 [ Mon Mar 16, 2009 7:38 pm ] |
| Author: | WestEndAngler [ Fri Mar 20, 2009 6:34 pm ] |
I bought a Gorilla Winch it works well cheap too! Bought mine on Ebay came with a complete accessory kit and free shipping. |
| Author: | 50fps [ Sun Mar 22, 2009 8:03 am ] |
I use a Superwinch 2000 that I picked up at Farm and Fleet for $69. Hooked a 18 inch chunk of chain with a hook, onto it so as to be able to hook it up anywhere on the hull depending on the circumstances. |
| Author: | Gigafowl [ Sun Mar 22, 2009 11:14 am ] |
Mitch, How do you keep it out'a the water ??? Being movable sounds like a good trick.... |
| Author: | WestEndAngler [ Mon Mar 23, 2009 2:20 pm ] |
| Author: | willett [ Mon Mar 23, 2009 2:32 pm ] |
you talkin bout quick connects on wires for the winch? If so how do you have that rigged up...needin ideas on that part |
| Author: | Sand Man [ Mon Mar 23, 2009 2:53 pm ] |
| Author: | Mitschke [ Mon Mar 23, 2009 3:02 pm ] |
Willett, i have some borg warner part numbers for Oreillys... They are a 6 gauge quick disconnect and all you have to do is insert the wire, crimp it to the pin, and insert the pin into the plastic housing. Pretty easy. Ill get it here in a little bit. |
| Author: | willett [ Mon Mar 23, 2009 3:22 pm ] |
good idea sand man I kinda want some kind of plug that can be mounted flush with the deck (cables under deck) and just quickly plug in because like alot of folks my winch isnt gonna be mounted permanently to the boat...any ideas for that besides the one sanders showed in the link? |
| Author: | Mitschke [ Mon Mar 23, 2009 3:35 pm ] |
Add 6 gauge and your good to go. You can see some of those pins i was talking about in some of the picture. If you do order them, order 2. 1 box only has one connector. |
| Author: | Sand Man [ Mon Mar 23, 2009 3:38 pm ] |
dynamite hooked you up. Pretty much the same connector warn uses. |
| Author: | Mitschke [ Mon Mar 23, 2009 3:43 pm ] |
Yessir! I think they are fairly inexpensive. Plus when you get all of the wire you need, you shall come up short of that warn kit. So call up the local Tyler O'reillys on Front street and order up some plugs! |
| Author: | Sand Man [ Mon Mar 23, 2009 3:46 pm ] |
FYI, if you run those leads all the way to the front of your boat, I would NOT leave them hooked to the battery. Don't ask why. I don't have time for another electrical lesson! |
| Author: | willett [ Mon Mar 23, 2009 9:11 pm ] |
thanks mitschke and sanders thanks for the input...the winch came with the solenoid like comes with atv winches but still wouldnt leave it hooked up all the time...do they even make a switch that can hook up that large of wire? |
| Author: | POKER1 [ Mon Mar 23, 2009 9:20 pm ] |
You gonna have a TM up front so just use the the same plug for your winch. I use a short piece of chain and chain it to the bow or stearn eyes depending on what way I plan to winch the boat. Or just use a couple shackles. Plug it into the TM plug front or back. I have the TM plugs on my TM, winch and HH lights. You can make up a short line with a female plug on one end and clips on the other if you plan to use your winch elsewhere. |
| Author: | POKER1 [ Mon Mar 23, 2009 9:24 pm ] |
| Author: | willett [ Mon Mar 23, 2009 9:26 pm ] |
yea was plannin on doing something to run everything off of...how large wire you run in that to power the winch |
| Author: | POKER1 [ Mon Mar 23, 2009 9:32 pm ] |
I think I used 8ga but my batteries are only a couple feet from the plugs front and back. If you gonna make a long run you probably need 6ga. |
| Author: | willett [ Mon Mar 23, 2009 9:38 pm ] |
yea thats what i was curious about connecting larger wire for a winch to a TM plug |
