It is currently Mon Sep 22, 2025 2:59 am
Reply to topic  [ 11 posts ]
 engine oil
Post engine oil
What engine oil and weight do you use in your motor and why?
Thanks in advance
Mon Aug 10, 2015 10:32 am
Post Re: engine oil
None... Because less weight = more fasterer!!!!
Mon Aug 10, 2015 10:42 am
Post Re: engine oil
Pm cb5331. He got the low down on oils.
Post Re: engine oil
Oh shit here we go!
Mon Aug 10, 2015 11:10 am
Post Re: engine oil
Use a veg oil, be clean and green
Mon Aug 10, 2015 11:22 am
Post Re: engine oil
:lol: been running the oil the girlfriend has in the drawer on her side of the bed that she got from Adam & Eve but that stuff is so slick your piston will slip out of the cylinder at high rpm's
Mon Aug 10, 2015 12:03 pm
Post Re: engine oil
I prefer water based lubricants. Much safer for the environment, and easier to make. If that's too much of a jump, 3 in 1 oil works well too.
Do a search. There are at least 3 oil threads within the last year. All offer good info, as well as some humor
Mon Aug 10, 2015 12:04 pm
Post Re: engine oil
Mon Aug 10, 2015 12:56 pm
Post Re: engine oil
Lol
Mon Aug 10, 2015 1:24 pm
Post Re: engine oil
15w40 Routella. Good enough for 100K peterbuilt, good enough for 7k mudmotor IMO
Mon Aug 10, 2015 2:26 pm
Post Re: engine oil
You can go 360 degrees on this and never get the same answer twice. Unless your warantee specifies using a particular brand, use what you have confidence in, and as a rule of thumb, use a heavier weight oil in the summer (heat will thin it down) and a lighter weight in the winter as cold will cause it to thicken. The most critical time oil plays its part is on initial startup. If your oil is thicker in winter, you're not getting good lubrication until the motor gets it warmed up.
Mon Aug 10, 2015 3:30 pm
cron
