It is currently Mon Sep 22, 2025 11:37 am
Reply to topic  [ 11 posts ]
 Eclectic reverse shaft extension removal.
Post Eclectic reverse shaft extension removal.
I have a buddy trying to remove his shaft extension on a 35 gtr electic reverse. Can anyone give me a heads up on how the shaft extension comes off the newer e reverse engines? My old model hydrauic reverse is just keywayed onto the briggs crank shaft but it doesn't seem this ones the same
17x54 custom CC with stage 3 GTR.
Sun Aug 09, 2015 2:39 pm
Post Re: Eclectic reverse shaft extension removal.
Gtail is making tillers with electric now?
GatorHide - MB
Sun Aug 09, 2015 2:51 pm
They got to keep up with MB.
Sun Aug 09, 2015 3:00 pm
Cancel that. Was just seized from rust. Comes off same way.
Sun Aug 09, 2015 3:23 pm
Sun Aug 09, 2015 3:40 pm
Sun Aug 09, 2015 4:00 pm
It takes a special puller
Sun Aug 09, 2015 4:48 pm
I have seen some guys beat them off with a punch and a hammer but I wouldn't do it
Sun Aug 09, 2015 4:49 pm
This is on a console model engine. The shaft extension came off with some serious force but after removing outer ring gear, now the belt drive pulley is seiszed also. Anyone know if we're overlooking some type of locking system on the e reverse models? Tried 4 ft cheater bars, with gear pullers and impacts for 3 hrs and no luck getting it off crankshaft.
Sun Aug 09, 2015 7:00 pm
think it may be time to get a professional involved
GatorHide - MB
Sun Aug 09, 2015 7:07 pm
Well, the professionals say its probably a case of fusion welding due to a bearing failure. Only advise was to cut through the gear/bearing and replace. Crankshaft has a nice size lip worn into it from race spinning at one point too so he likely wont be looking at too cheap of a fix.
Mon Aug 10, 2015 12:43 pm
