MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
engine oil https://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=63148 |
Author: | 13 pistols [ Mon Aug 10, 2015 10:32 am ] |
Post subject: | engine oil |
What engine oil and weight do you use in your motor and why? Thanks in advance |
Author: | SETx Longtail [ Mon Aug 10, 2015 10:42 am ] |
Post subject: | Re: engine oil |
None... Because less weight = more fasterer!!!! |
Author: | msm8281 [ Mon Aug 10, 2015 10:42 am ] |
Pm cb5331. He got the low down on oils. |
Author: | HOTSAUCE170 [ Mon Aug 10, 2015 11:10 am ] |
Oh shit here we go! |
Author: | scarygary [ Mon Aug 10, 2015 11:22 am ] |
Use a veg oil, be clean and green Sent from my iPhone using Tapatalk |
Author: | 13 pistols [ Mon Aug 10, 2015 12:03 pm ] |
Author: | Russ [ Mon Aug 10, 2015 12:04 pm ] |
I prefer water based lubricants. Much safer for the environment, and easier to make. If that's too much of a jump, 3 in 1 oil works well too. Do a search. There are at least 3 oil threads within the last year. All offer good info, as well as some humor |
Author: | cb5331 [ Mon Aug 10, 2015 12:56 pm ] |
Author: | msm8281 [ Mon Aug 10, 2015 1:24 pm ] |
Lol |
Author: | DENNYEDWARDS [ Mon Aug 10, 2015 2:26 pm ] |
15w40 Routella. Good enough for 100K peterbuilt, good enough for 7k mudmotor IMO |
Author: | cheniermudder [ Mon Aug 10, 2015 3:30 pm ] |
You can go 360 degrees on this and never get the same answer twice. Unless your warantee specifies using a particular brand, use what you have confidence in, and as a rule of thumb, use a heavier weight oil in the summer (heat will thin it down) and a lighter weight in the winter as cold will cause it to thicken. The most critical time oil plays its part is on initial startup. If your oil is thicker in winter, you're not getting good lubrication until the motor gets it warmed up. |
