It is currently Fri Sep 19, 2025 10:37 am
Reply to topic  [ 4 posts ]
 Broken Valve Cover Bolt
Post Broken Valve Cover Bolt
Hi guys.. I was going through my motor last night, checking valve lash, changing oil, checking spark plugs, etc.... Everything checked out great and when I was putting the valve covers back on, I broke one of the bolts.. Are these standard bolts from the hardware store or do I need to get a special briggs bolt from a dealer?? Thanks in advance.
1852 Phowler Extreme - Phowler Light Marsh Blind - Mud Buddy 45 mag w/ Heads, Mikuni, Q exhaust, and Hammer Prop
Wed Aug 12, 2015 4:48 am
Post Re: Broken Valve Cover Bolt
Its a metric flange bolt. If you can find the correct length, you can replace it with one of the same size from a good HW store.
OEM replacement is Briggs and Stratton PN# 807357 < $2
http://www.jackssmallengines.com/search ... 1&q=807357
Wed Aug 12, 2015 5:20 am
I believe it's a 30mm, m8-20 (got mine from tractor supply, but the package is at the house so I can't check it at the moment).
Wed Aug 12, 2015 5:35 am
Awesome, thanks fellas!!
Wed Aug 12, 2015 7:12 am
