Broken Valve Cover Bolt
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=63195
Author:  dannym2009 [ Wed Aug 12, 2015 4:48 am ]
Post subject:  Broken Valve Cover Bolt
Hi guys.. I was going through my motor last night, checking valve lash, changing oil, checking spark plugs, etc.... Everything checked out great and when I was putting the valve covers back on, I broke one of the bolts.. Are these standard bolts from the hardware store or do I need to get a special briggs bolt from a dealer?? Thanks in advance.
Author:  deadbird8 [ Wed Aug 12, 2015 5:20 am ]
Post subject:  Re: Broken Valve Cover Bolt
Its a metric flange bolt. If you can find the correct length, you can replace it with one of the same size from a good HW store.
OEM replacement is Briggs and Stratton PN# 807357 < $2
http://www.jackssmallengines.com/search ... 1&q=807357
Author:  Russ [ Wed Aug 12, 2015 5:35 am ]
I believe it's a 30mm, m8-20 (got mine from tractor supply, but the package is at the house so I can't check it at the moment).
Author:  dannym2009 [ Wed Aug 12, 2015 7:12 am ]
Awesome, thanks fellas!!
