| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| Clutch??? https://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=71381 |
| Author: | ibfishinb [ Sat Oct 07, 2017 7:42 pm ] |
| Post subject: | Clutch??? |
We were riding along and I notice smoke pouring out of the plastic clutch/caliper housing on my buddies 2013 GTR. He said that something felt a bit odd, but it was still cruising along at about 30mph. Haven't pulled it apart yet because he is waiting for the plastic housing to cool off. It was melting and very mushy... didn't want to destroy it taking it apart. I just went ahead and towed him the last mile to the ramp. Didn't want to cause any further damage. Anyone had this happen and have a diagnosis? Sent from my SM-G920V using Tapatalk |
| Author: | brycecheramie [ Sat Oct 07, 2017 8:06 pm ] |
| Post subject: | Re: Clutch??? |
| Author: | Russ [ Sat Oct 07, 2017 9:47 pm ] |
not a plastic clutch cover melting??? that can't happen... #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | ibfishinb [ Sun Oct 08, 2017 5:52 am ] |
Yea.... We went and grabbed a late lunch with the wives while the cover resolidified. Then it was time for college football and "fuck it.... I'll look at it tomorrow". Sent from my SM-G920V using Tapatalk |
| Author: | ibfishinb [ Sun Oct 08, 2017 11:45 am ] |
Looks like something moved and cause the planetary housing to rub the caliper. Sent from my SM-G920V using Tapatalk |
| Author: | jc [ Sun Oct 08, 2017 1:08 pm ] |
Check the motor mounting bolts and where the side plates that meet the lower unit. If you squeeze the belt together real hard you may be able to see what is moving. Also check the center bolt that holds the planetary to the motor shaft. |
| Author: | jc [ Sun Oct 08, 2017 1:33 pm ] |
I have seen it hit before but not that bad. When the belt is under load it makes the shaft flex down but it usually won't hit like that unless you hit some stumps or maybe really heavy mud. Check these bolts. |
| Author: | Russ [ Sun Oct 08, 2017 1:54 pm ] |
I'd check the crank bolt and the screws inside the planetary, and the caliper bolts. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | jc [ Tue Oct 10, 2017 5:29 pm ] |
Did you find out what the problem was? |
| Author: | MaXXis85 [ Wed Oct 11, 2017 6:20 am ] |
That gen 2 caliper is notorious for sticking.... and then flexing then rubbing the ring gear housing. Your pads are probably worn at an angle... |
| Author: | TPerkins [ Wed Oct 11, 2017 1:29 pm ] |
It can always be worse.. Sent from my SM-G930V using Tapatalk |
| Author: | Russ [ Wed Oct 11, 2017 1:36 pm ] |
so.....THAT happenned...... sympathies #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | brycecheramie [ Wed Oct 11, 2017 5:06 pm ] |
It could be worse! You could NOT have Ricky Bobby overseeing the shop... |
| Author: | bluesky2012 [ Wed Oct 11, 2017 7:12 pm ] |
| Author: | Will C [ Wed Oct 11, 2017 7:50 pm ] |
Dammit... second rebuild for 2017? |
| Author: | TPerkins [ Wed Oct 11, 2017 8:19 pm ] |
Broken rocker boss early in the year and now this.... Not really sure what direction to go from here. Sent from my SM-G930V using Tapatalk |
| Author: | TPerkins [ Wed Oct 11, 2017 8:28 pm ] |
Holy Jesus Bluesky, just read through that thread. I can say the belt tension was completely fine. I think it had more to do with the 50lbs of clutches/planetary cantilevering on the rear bearing. Additional power may have helped end it but was definitely not the route cause. Sent from my SM-G930V using Tapatalk |
| Author: | CypressCritter [ Wed Oct 11, 2017 8:32 pm ] |
SHIIIIIIIIITTT!!!! That makes me almost wanna buy a Sport V or a ProDrive! |
| Author: | brycecheramie [ Wed Oct 11, 2017 8:46 pm ] |
| Author: | TPerkins [ Thu Oct 12, 2017 7:17 am ] |
The Hoss definitely has my eye! Sent from my SM-G930V using Tapatalk |
| Author: | 3rd Coast Killer [ Thu Oct 12, 2017 7:55 am ] |
| Author: | OwenDickeson [ Thu Oct 12, 2017 5:50 pm ] |
| Author: | MaXXis85 [ Fri Oct 13, 2017 6:06 am ] |
I've heard of a few times this happening. Its not the Normal, But it has happened more than once. The root cause??? Bad crank, The unbalanced weight hanging off the back, the abuse these units see, and many other unseen options. IMO there needs another bearing to support that additional weight that will help alleviate some stress off the PTO. |
| Author: | TPerkins [ Fri Oct 13, 2017 7:06 am ] |
| Author: | Russ [ Fri Oct 13, 2017 8:22 am ] |
I'll do it free, you just have to buy the necessary replacement parts and drive up here. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | MaXXis85 [ Fri Oct 13, 2017 8:24 am ] |
| Author: | Russ [ Fri Oct 13, 2017 8:27 am ] |
only a starter. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | ibfishinb [ Fri Oct 13, 2017 11:47 am ] |
Maxxis got it. My buddy ordered the latest gen to replace it. Sent from my SM-G920V using Tapatalk |
