| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| 2015 Gtr 35 mikuni/e-pump install ? https://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=71406 |
| Author: | Pintail1992 [ Thu Oct 12, 2017 11:43 am ] |
| Post subject: | 2015 Gtr 35 mikuni/e-pump install ? |
Just received my carb kit and and exhaust from Delta. Delta said I didn't have to but recommended that I run an E-pump. Any of you guys have some insight or any pics of how you mounted your E-pump to the motor?? |
| Author: | Russ [ Thu Oct 12, 2017 11:47 am ] |
| Post subject: | Re: 2015 Gtr 35 mikuni/e-pump install ? |
I run mine 6-12" from the gas tank through (currently) 8' of fuel line to the engine. I was running about 15', but it was time to put new line on and didn't use as much. It's not vibrating with the engine with it in the boat. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Pintail1992 [ Thu Oct 12, 2017 12:09 pm ] |
Ok thanks. So you did you bypass your manual pump all togheter or leave it inline. May be a dumb question but I'm new to do any mods on these motors. I see a lot of guys say you don't need to run an e-pump But I got it so I figured I would give it a shot |
| Author: | Russ [ Thu Oct 12, 2017 12:31 pm ] |
Never had a stock pump installed. Built this engine from a parts engine and some aftermarket additions myself. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | MaXXis85 [ Fri Oct 13, 2017 6:01 am ] |
if your stock fuel pump is working fine, You will be fine. |
| Author: | CypressCritter [ Fri Oct 13, 2017 8:01 am ] |
I got 12-15 ft of fuel line(5/16), impulse type pump, tank built in to console, primer bulb and fuel filter within the 1st 2 ft., works good for me, and I am running a mikuni carb. with 3/8 line in my other boat had issues kept losing prime at low speeds. |
