It is currently Fri Mar 27, 2026 2:11 am
[ 5 posts ] |
23 Vanguard mini problems
Rmhull3
Howdy folks. I'm wondering if anyone has ever had a problem like this. I bought a used 23 hp vanguard mini with high performance cams and a bps exhaust. I have had problems with the motor losing power on the top end. I happens more so with the load. Other guys have the same motor without the upgrades and don't have near the problems I do . Thought it might be a fuel issue but buddy told me to put a fuel pump on and it should help it. The engine seems to overheat and lose power. Tends to backfire. New short block. Help please
| Sat Oct 14, 2017 12:39 am |
Rmhull3
 Re: 23 Vanguard mini problems
It is on a 16' 48" alumacraft. Once on a plain at full throttle it's like looses compression and power. Has a rev limiter and threw a rod. Hence new short block. Go back to stock? Too much of a load?
| Sat Oct 14, 2017 12:49 am |
brycecheramie
| Sat Oct 14, 2017 12:55 am |
Rmhull3
| Sat Oct 14, 2017 7:12 am |
brycecheramie
| Sat Oct 14, 2017 7:22 am |
[ 5 posts ] |
