It is currently Fri Mar 27, 2026 12:31 pm
Reply to topic  [ 8 posts ]
 Prodrive noise
Post Prodrive noise
Any idea what my issue might be here? Posted on fb and got several suggestions from bearing to clutch. Sure would like to get it narrowed down vs just throwing parts at it. So figured I'd post here as well. Certainly seems like it's coming from the top of the tower. Initially I thought it was a bearing in the lower knuckle. I can bump it up in rpms and the noise stays constant at the top of the tower. Any advice appreciated.
https://youtu.be/ME6JVR_GyCA
1850 & 36pd
Fri Oct 13, 2017 7:28 pm
Post Re: Prodrive noise
Sounds like a clutch that's about to fail, IMO.
Refurbishing a Prodrive
Fri Oct 13, 2017 7:46 pm
On second thought, is there any possibility that the bolt holding the clutch on the shaft is loose?
Either way, you may as well start pulling the powerhead!
Fri Oct 13, 2017 7:47 pm
Fri Oct 13, 2017 8:56 pm
Clutch bearing
driving a gd in ur lake
and i aprove this message
Fri Oct 13, 2017 11:20 pm
Post Prodrive noise
Thanks fellas. Owen offered to help me out with it. If the clutch is junk do I have to get it from pd? Clutch has around 80hrs on it.
1850 & 36pd
Fri Oct 13, 2017 11:32 pm
A couple people have tried these. I put one on my prodrive that I just recently sold and didn't have any issues with it.
Havent heard of them failing yet.
https://www.amazon.com/s/ref=nb_sb_noss ... ive+clutch
Fri Oct 13, 2017 11:44 pm
Thx man
1850 & 36pd
Sat Oct 14, 2017 6:17 am
