It is currently Sat Mar 28, 2026 3:35 am
[ 8 posts ] |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Prodrive noise
Any idea what my issue might be here? Posted on fb and got several suggestions from bearing to clutch. Sure would like to get it narrowed down vs just throwing parts at it. So figured I'd post here as well. Certainly seems like it's coming from the top of the tower. Initially I thought it was a bearing in the lower knuckle. I can bump it up in rpms and the noise stays constant at the top of the tower. Any advice appreciated. https://youtu.be/ME6JVR_GyCASent from my iPhone using Tapatalk
_________________ 1850 & 36pd
| Fri Oct 13, 2017 7:28 pm |
brycecheramie
 Re: Prodrive noise
Sounds like a clutch that's about to fail, IMO.
| Fri Oct 13, 2017 7:46 pm |
brycecheramie
 Re: Prodrive noise
On second thought, is there any possibility that the bolt holding the clutch on the shaft is loose?
Either way, you may as well start pulling the powerhead!
| Fri Oct 13, 2017 7:47 pm |
BlueShamu
 Re: Prodrive noise
| Fri Oct 13, 2017 8:56 pm |
meterman3
 Re: Prodrive noise
Clutch bearing
_________________ driving a gd in ur lake and i aprove this message
| Fri Oct 13, 2017 11:20 pm |
med
 Prodrive noise
Thanks fellas. Owen offered to help me out with it. If the clutch is junk do I have to get it from pd? Clutch has around 80hrs on it.
| Fri Oct 13, 2017 11:32 pm |
brycecheramie
 Re: Prodrive noise
A couple people have tried these. I put one on my prodrive that I just recently sold and didn't have any issues with it. Havent heard of them failing yet. https://www.amazon.com/s/ref=nb_sb_noss ... ive+clutch
| Fri Oct 13, 2017 11:44 pm |
med
 Re: Prodrive noise
Thx man
| Sat Oct 14, 2017 6:17 am |
[ 8 posts ] |
