It is currently Wed Mar 25, 2026 2:39 am
[ 6 posts ] |
jred00
 Marsh Intercoastal Boat
New to this arena and would appreciate your insight.
My house backs up to marshland that is tidal in Florida. About 500 feet through the marsh I can reach the intercoastal waterway.
I'd like to put together a boat that can hunt ducks/fish and be able to move the best at low tide. There are definately logs and stumps in the marsh, but I suspect I'll be able to discover a satisfactory path after a few attempts. Once in the intercoastal I may travel 5-10 miles to hunt. I'm going to launch the boat from my backyard with a golf cart (boat cant be too heavy)
I'm looking at an alumacraft 1542 (210 lbs) with a 23 hp beavertail long tail motor. I suspect the trips will generally be two adults for hunting. Does this seem like a reasonable set up, or should I be looking to buy a different set up. Completely new to this. Thanks
| Wed Dec 16, 2015 5:14 am |
TexasGDvl13
Joined: Tue Mar 22, 2016 4:59 am Posts: 32 Location: Houston, TX
 Re: Marsh Intercoastal Boat
Depends on how fast you want to go and in the intercoastal it's going to suck with that long tail. If you aren't making a very long run and you just want to put around you will be alright but if I were you and it was in my budget I would look into a surface drive.
_________________ 2013 Go Devil 1860/ 35hp GDSD
| Tue Mar 22, 2016 6:03 am |
Russ
Go 16 ft with the longtail, or a bit wider with a surface drive. 1644 w/lt, or 1546-48 w/sd. What you listed would be fine for your expectations, but once you get to deeper water, the extra lift will let it run higher, and be a tad more stable. That's a long run with a longtail, but it'll do the job. Figure your budget, and go from there.
| Tue Mar 22, 2016 8:53 am |
brstanle
Joined: Sun Oct 05, 2014 12:27 am Posts: 659 Location: SETX/Houston
Longtails are great machines and cost effective but they're a workout. I would try finding someone around you with a Longtail setup that you can try so you know what you're getting into beforehand.
_________________ 35 GTR w/ 1860 GoDevil "Ironsides"
| Tue Mar 22, 2016 9:33 am |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
| Tue Mar 22, 2016 9:45 am |
Will
Where are you at in Florida?
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Wed Mar 23, 2016 4:38 am |
[ 6 posts ] |
