It is currently Tue Mar 17, 2026 9:38 am
Reply to topic  [ 28 posts ]
 Pro-drive reverse pin !!!!!
Post Pro-drive reverse pin !!!!!
Have any of you pro-drive guys ever lose the pin for your reverse while wide open?Had a buddy and two other fellas lose his and wrecked out into a cypress tree two of them got hurt pretty bad
Sent from my iPhone using Tapatal
Stock 35gdsd skidding 1654gd
Thu Feb 12, 2015 6:47 pm
Post Re: Pro-drive reverse pin !!!!!
Were these PD new units?
If not, was there any normal maintenance performed by the owner on these manual reverse units.
I look over my stuff before I go out knowing I'm going into a dangerous environment. But that is me. And I never had the reverse pin fall out. :D
Thu Feb 12, 2015 7:14 pm
It was only one boat and he recently just purchased the boat used.I believe it's a 2010 and he's a pretty sharp guy and keeps good maintenance on his rig
Thu Feb 12, 2015 7:37 pm
Hope no one got hurt.
Thu Feb 12, 2015 7:43 pm
One guy got leg broke,one got a broken foot and busted knee,the other got bruises
Thu Feb 12, 2015 7:56 pm
Good lawd
35 GTR - 1754 Extreme
Thu Feb 12, 2015 8:12 pm
I bent the housing that holds the pin before opener this year. It kept the pin from fully locking in. Well on the way to the blind at full speed she popped out and I damn near got ejected. It's definitely a scary feeling!
Thu Feb 12, 2015 8:37 pm
The pin doesn't just fall out, it shears off. I have broken one.
Thu Feb 12, 2015 9:19 pm
Thu Feb 12, 2015 9:25 pm
[SMILING FACE WITH OPEN MOUTH AND SMILING EYES]
Thu Feb 12, 2015 9:27 pm
40HP Gatortail
Fri Feb 13, 2015 3:22 pm
1654 Grizzly
'13 35 GDSD
"You should be more concerned with watching football than making chit fall out the sky!!!"
- My Wife
Fri Feb 13, 2015 3:53 pm
There ought to be a fail-safe mechanism in the event of a failure like the pin shearing or dropping out. The consequences of such a failure are too serious not to have one. Do the remote pullers have a lock down mechanism to prevent accidental triggering? I'm sure the prodrive engineers are on this or have already made adjustments to prevent this from happening again.
Fri Feb 13, 2015 4:01 pm
Holy Crap! Yall are making me nervous now.
Tue Feb 17, 2015 4:47 pm
Mine broke last day of season here, but the main pin stayed in the reverse plate and i just lost the handle.
See what my post. Since then PD already fixed it for me.
viewtopic.php?f=3&t=59744
1848 GTB, 36 PD w/ FPR
Fri Feb 20, 2015 11:15 am
Hey, guys this happened to me saturday during that poker run..
I lost my pin running wide open threw a 3 mile slu...
Didn't notice till I reached back to pull the pin....Didn't loose control ran back at 1/2 throttle open river cautiously.
Good thing that PD can't out run my guardian angel
How do I fix this my self 08pd 36 fpr manuel reverse...
As far as I can't tell it "looks" like the T handle had just simply fell out. The nut that tightens into the sleeve to hold assembly togeather is still tight.
I can't feel any rod nor see far enough into the sleeve it's possible it sheerd off... I greese my motor every 4th time I take it out as far as maintenance Goes.
But I should be able to simply put a new assembly in its place? Or will there be machine work to be done?
Going to Disney World is like Going To the DMV, Instead of Walking out Once Finished Jumping Back In Line At the DMV…
Mon May 09, 2016 5:21 am
Call prodrive. They did a recall and were swapping the plates out.
Mon May 09, 2016 8:51 am
Yes sir cb, you are correct they are swapping it out for free
Mon May 09, 2016 10:20 am
How the hell are the pins "falling" out? Its threaded. Even if the spring fails, the insert is threaded, it shouldn't fall completely out. Now if it wasn't tight, maybe
Mon May 09, 2016 10:29 am
BTW, I actually have one in my shop lying around. Took it out when I went to hydro. Yall can have it if you want, just cover the shipping. Just PM me an address.
Mon May 09, 2016 10:31 am
They still swapping them for free? Mine fell out today while running traps
18x40 skiff/35 hp GTR
Wed May 25, 2016 2:15 pm
40HP Gatortail
Wed May 25, 2016 8:47 pm
The pin breaks and the handle falls off. The larger part stays in the rotating plate.
Fri Aug 12, 2016 11:40 am
Was on the phone with a PD dealer who mentioned this recall by PD. Had not heard of this so came on MMT and searched it. Holy crap!! Never had any issues yet, but part is on order, no charge.
Fri Aug 12, 2016 1:32 pm
when u buy used parts/gear, you are buying other people's junk. when it breaks there is no one to blame but yourself.
Fri Aug 12, 2016 3:31 pm
Has anyone had the pin come out but the T-shape part stay intact? Was running wide open in mine today when the foot took an immediate left turn. Scary shit for sure. When I got back in, the foot was definitely turned but it clicked back in forward like normal. I ran back a couple miles trying to get it to break loose again to no avail. I can't see an obvious problem but I don't trust it until I can get a new pin.
Fri Oct 21, 2016 8:32 pm
I've had the t handle break off, but the motor just stays in whatever position u have it in. the pin is way bigger than the little hole for the handle.
wade660, call pd and get the updated reverse.
Fri Oct 21, 2016 9:51 pm
Sat Oct 22, 2016 5:09 pm
