It is currently Tue Mar 17, 2026 9:38 am
[ 6 posts ] |
Keep this plywood on transom?
Exbellicus
Ordered my first mud motor - a 25efi Prodrive /w reverse. It should be here this week. On my transom there is currently a square of plywood - it appears it's riveted in. Should this be removed to mount my motor?
_________________ 2016 Prodrive X 1848 37efi
| Mon Nov 07, 2016 11:32 am |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
 Re: Keep this plywood on transom?
First impression would be no - don't remove it. Did you install the wood? It might be there to help strengthen it up for reasons unbeknownst to you.
If might be a good idea to remove it and beef it up correctly.
Pull it off and have a look. Get more photos. You can always put it back.
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
| Mon Nov 07, 2016 1:32 pm |
Buckmark311
remove wood, beef with aluminum channel and square tubing (the right way)
| Mon Nov 07, 2016 4:12 pm |
dead animal
get rid of the wood and get a welder to beef up the transom and put braces on the corners. u will break that transom, just a matter of time.
| Mon Nov 07, 2016 8:02 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
Take it out and put some aluminum there.
The wood holds water that will end up rotting the aluminum eventually.
| Mon Nov 07, 2016 8:04 pm |
brickgw
Yeah...ive rebuilt a wood transom and it sucks. Better to just do it right the first time if possible.
| Mon Nov 07, 2016 8:13 pm |
[ 6 posts ] |
