It is currently Tue Mar 17, 2026 4:03 am
[ 4 posts ] |
dennishaussler
 27 PD won;t push boat
I have an 04, 27 PD on a 15x65, thats at the gunnels, aluminum valco. It was originally a jet sled boat built in the 70's. I picked it up and did alot of work to it, reinforce transom, extra skin on bottom, etc. Boat is a nice layout, but the 27PD I have on it won;t plane with 2 guys, dog and gear. With just me and some gear it will plane out and I can get about 22mph out of it at 3850rpm. With an additional 300lbs, it won;t come up on plane. I have tried trimming the motor full spectrum of movement, no joy. I have small pods I welded on, they help but it still won;t come up. Anyone have info on props and how they might help? I don;t think its a HP issue, as the motor doesn;t lug, it just cavitates at a certain point, then its all over. Any help or direction would be greatly appreciate.
| Mon Jan 09, 2017 9:19 am |
Quack N Stack
Joined: Sat Dec 15, 2012 9:43 pm Posts: 2225 Location: Baytown, Tejas
 Re: 27 PD won;t push boat
Your right ots not a HP issue but its also not a prop issue either. Its a hull design issue. I don't know a whole lot about pro drives but one thing i do know is they are very picky about transom height and angle...also pods are are probably not noticeable when you by your self but probably doing more harm than good with load. They dont allow water to get to the prop correctly
| Mon Jan 09, 2017 9:47 am |
dennishaussler
Whats the angle at the transom that works best for PD's?
| Mon Jan 09, 2017 10:44 am |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
Short wide boat and a small block isn't helping either. PD is either a 15 or 16 dog transom angle, but it's more of a "boat not made for the motor" problem. Surface drives are picky about the hulls that perform well with them, and when you drop to a small block the mismatch is magnified that much more.
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
| Tue Jan 10, 2017 5:21 pm |
[ 4 posts ] |
