It is currently Tue Mar 17, 2026 1:32 pm
[ 5 posts ] |
boatguy
Joined: Mon Dec 05, 2016 11:59 am Posts: 219 Location: Panhandle of Florida
 RPM ????
DELETED....
_________________ Lead, Follow or Get The Hell Out Of The Way!!!! 1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
| Mon Feb 27, 2017 7:05 am |
brycecheramie
 Re: RPM ????
Yeap, your rpms are off. There is no way in hell you are turning anywhere close to 8000 rpms.
| Mon Feb 27, 2017 7:06 am |
brycecheramie
 Re: RPM ????
You're also in the wrong section. Would get more help if it were in the Engines section. Cause an engine is not a boat or blind
| Mon Feb 27, 2017 7:18 am |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
 Re: RPM ????
How many times is your lead wrapped around your plug wire? Sometimes that makes a difference. The manf. suggest 3-4 wraps max. I've had that before. Also if it gets wet it def. makes the tach do some funny shit at times. I've had them read 360 deg. and reset to zero hours. Not the best units but more readily available than other types and much less expensive than alternatives. The tach i'm looking into getting is over $125.00, but have yet to pull the trigger on it for that simple reason.
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
| Mon Feb 27, 2017 7:41 am |
boatguy
 Re: RPM ????
| Mon Feb 27, 2017 7:44 am |
[ 5 posts ] |
