It is currently Tue Mar 17, 2026 5:38 am
Reply to topic  [ 4 posts ]
 aluminum seat base
Post aluminum seat base
the aluminum 7"x7" seat base can i weld that in my boat instead of bolting it? i have a 1/8 5086 sub floor in my boat i wont be able to get under it to bolt
Mon May 01, 2017 6:58 pm
Post Re: aluminum seat base
If it's the cast aluminum, yes. Hillside Castings makes a particular base for the floor with a short pedestal hole.
Mon May 01, 2017 7:16 pm
at there site now thank you
Mon May 01, 2017 7:18 pm
Another option is seat spiders you can sit where you want I made some and haven't used my post since mine are made from aluminum seat base and bent 1/2 inch aluminum pipe if you make some use AL pipe much cheaper than tubing
Fri May 05, 2017 1:16 am
