It is currently Tue Mar 17, 2026 9:30 am
Reply to topic  [ 15 posts ]
 DIY boat blind ideas?
Post DIY boat blind ideas?
How many of you guys have built your own blinds that break down. I've looked at a couple designs with the Bemini hardware but worry about it breaking in the cold.
Sat Sep 09, 2017 9:01 pm
Post Re: DIY boat blind ideas?
Do a search. I used 3/4 electrical conduit and the plans from a scissor blind a guy did on here. Used the Bimini connections 7/8" and had to bore them out a bit (no bid deal with a drill and sanding wheel)
I just finished it last week. It works amazing. Only had to drill two connections for the stern section of the blind (Bimini mail connections on the port and stbd side of the boat... I used rivets) and that was the only place I needed to put holes. I used the frond seat mount for the bow section of the blind. Made a T bar and it just slides in the seat hole
Lead, Follow or Get The Hell Out Of The Way!!!!
1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
Sun Sep 10, 2017 5:55 am
Profile YIM
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=4280
http://www.duckworksbbs.com/hardware/bimini/index.htm
2016 Prodrive X 1848 37efi
Mon Sep 11, 2017 3:44 am
You can get metal Bimini hardware aswell if you look up my screen name on the duck hunters refuge forum I've built sever different blind styles on there
Wed Sep 13, 2017 1:05 am
If you make a true scissor type blind, no fittings required. I use 1/2 conduit with 3/4 pre-bend 90s, and couple of short 3/4 pieces to make it longer. (could only find 8 ft. 1/2 conduit) Holding it together with SS self tapping screws, youtube it! cheapest way, those Bimini fittings are close to $20 a piece.
Wed Sep 13, 2017 7:52 am
Here is mine that I made:
Sat Sep 16, 2017 9:11 am
exbellicious that is exactly the kind I'm looking at building
Sat Sep 16, 2017 12:03 pm
Heres mine i made it out of 3/4 conduit based off one i saw on here. I used a piece of solid aluminum rod that fit snug inside the pipe to connect the elbows to my center pieces and bolted it together.
Sun Sep 17, 2017 3:40 am
I made something similar to this using conduit with a bender and a few fittings/bolts/nuts from the hardware store. Very simple and easy to put up with one person. One end is secured with a bolt and wingnut locking the two sides together and the other end has a trailer hitch lock pin to hold that side together.
Wed Oct 25, 2017 10:16 am
Go with 3/4 rigid conduit. It's stout
Thu Oct 26, 2017 8:18 am
I threw this together last season. My plan is to go with raffia grass on some netting with a cordura backing for a wind breaker. It could use some design tweaking, but I'm happy with it for $80 in bimini hardware and $20 in 3/4" EMT conduit.
Thu Oct 26, 2017 8:37 am
Here is a video of mine. https://youtu.be/tgKsIAcWNzg
Sent from my SM-T810 using Tapatalk
Sat Dec 16, 2017 9:16 pm
Not sure what style of gunnel rails you have. I have the accessory type so this is what I did. I made 4 brackets out of bent aluminum plate anchored with carriage bolts that slide into the rail where I mounted my bimini hardware. It's a scissor type blind so I can pull 4 pins and take it off the boat in a few mins. I believe all of my bimini fittings are 1" inner diameter so I made the frame with 1" grey electrical conduit. Had to put some tubing inside the long sides to keep it from sagging in the middle with the weight of the fastgrass. Agree the the stainless bimini hardware is kinda pricey but it sure is convenient to put on and take off.
22'x72" Boatright w/ 200 Yamaha SHO
14' Alumacraft w/ modded 6.5 Backwater
Sat Dec 16, 2017 10:23 pm
I threw this together 2 years ago still holding up strong
Mon Dec 18, 2017 1:43 pm
Best prices I found for SS bimini hardware was at marinepartdepot dot com
Thu Dec 21, 2017 6:21 am
