It is currently Tue Mar 17, 2026 12:42 am
[ 7 posts ] |
Estel1m
 Weld on pods?
Debating getting pods welded onto my hull. Anyone done this? Is it worth it? Pros and cons? I run a 27hp prodrive on a 1752 Alweld. Any advice is appreciated.
| Thu Dec 14, 2017 5:01 pm |
Russ
 Re: Weld on pods?
yes. no. the juice ain't worth the squeeze.
| Thu Dec 14, 2017 5:16 pm |
cb5331
 Re: Weld on pods?
| Thu Dec 14, 2017 6:59 pm |
BlueShamu
Joined: Mon Feb 06, 2012 6:13 pm Posts: 5605 Location: D'town, LA
 Re: Weld on pods?
Simply amazing!
| Fri Dec 15, 2017 8:17 am |
brycecheramie
 Re: Weld on pods?
Why would you want pods on a boat that size anyway???
| Fri Dec 15, 2017 8:53 am |
pdk
Joined: Sun Jul 05, 2015 3:13 pm Posts: 14 Location: So. Minn
 Re: Weld on pods?
I had them on a 1648 Lowe with a 35 Mudbuddy. They helped carry the load. The down side I noticed was when I would put the boat in the weeds and try to get it out. When I tried to push it backwards the mud and weeds would build up between the pods making it a real pain to try and back out of the weeds/reeds. I put the same motor on an 1850 Phowler Extreme. For what it's worth, night and day difference. No pods needed and the boat handles the weight of the motor better than the 1648 with the pods.
| Tue Dec 19, 2017 8:03 pm |
dennishaussler
 Re: Weld on pods?
Put pods on similar size boat, same motor, and it completely robbed good water from the prop. Could not get the thing to do above 10mph with 2 guys and dog. Cut the pods off, problem solved.
| Thu Dec 21, 2017 6:55 pm |
[ 7 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 1 guest |
