Custom boat for an outboard
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=54701
Author:  bassinsouthla [ Thu Jul 10, 2014 8:19 pm ]
Post subject:  Custom boat for an outboard
I am looking for suggestions as to who builds a good custom boat with large front deck with storage and rod box for an outboard at an affordable price. I am looking to have someone build something no larger than an 18 x 54 for a tiller. Possibly a tunnel but seems like someone really needs to know how to build one in order for it to perform correctly. Any info would be appreciated.
Author:  nasty [ Wed Jul 16, 2014 4:40 pm ]
Post subject:  Re: Custom boat for an outboard
Capt. jj.. hes built a few tunnelhulls. Or dfou
Author:  msm8281 [ Wed Jul 16, 2014 4:43 pm ]
Eric Romero(custom aluminium boats) in Lydia La. Has experience with tunnels.
Author:  careybrowning [ Thu Jul 17, 2014 11:15 am ]
I just tested a nice 1854 with 24" sides Prodigy with a 70 yamaha on it this very morning. It was a sweet setup. Kinda made me miss outboards.
Author:  DUCK HEARSE [ Thu Jul 17, 2014 11:16 am ]
Author:  careybrowning [ Thu Jul 17, 2014 11:25 am ]
It ran a solid 38 this morning. The rpms were low though so it needs to try some different props to get it dialed in right. It was fun though after running mud motors for so long.
Author:  Prodigy [ Thu Jul 17, 2014 11:43 am ]
38 w 2 guys, 2 coolers, 2 large optimas, trolling motor, 20 gallons of fuel..........
turning 5600 rpms.........need to drop to a 15 pitch power tech to get the rpms up more...........
Author:  msm8281 [ Thu Jul 17, 2014 11:46 am ]
5600 sounds right with that load. Empty you should be close to 6000.
Author:  Prodigy [ Thu Jul 17, 2014 11:48 am ]
Gonna c what the 15 does........these F70's are really sweet...............
Author:  Frog [ Thu Jul 17, 2014 12:51 pm ]
How much does the F70 cost with binnacle and set up for steering ?
Author:  Prodigy [ Thu Jul 17, 2014 6:42 pm ]
Call me tomorrow
Author:  DUCK HEARSE [ Thu Jul 17, 2014 6:55 pm ]
Author:  mizzippi jb [ Thu Jul 17, 2014 7:03 pm ]
Is that shep's boat?
Author:  Prodigy [ Thu Jul 17, 2014 7:05 pm ]
It is.. Got another one also but w 21" sides out there and building 2 more now.
Author:  mizzippi jb [ Thu Jul 17, 2014 7:08 pm ]
That was the one outside in the lot today I guess...(sheps)
Author:  Prodigy [ Thu Jul 17, 2014 7:14 pm ]
Yes sir
Author:  Nate [ Fri Jul 18, 2014 5:20 am ]
Prodigy- is that a tunnel hull?
Author:  nocemdead [ Fri Jul 18, 2014 11:54 am ]
Thirdtimesacharm does tunnels
Author:  DUCK HEARSE [ Fri Jul 18, 2014 3:27 pm ]
Call Robert at extreme metal fabrication
Author:  Prodigy [ Fri Jul 18, 2014 10:08 pm ]
That one doesn't have a tunnel but we can do.
Author:  Prodigy [ Fri Jul 18, 2014 10:09 pm ]
Haven't run a 90.. The f70 is so much lighter and is a sweet engine that doesn't burn much fuel..... 90 would prob get into low to mid 40"s I'd think..
Author:  Bad Boy [ Fri Jul 18, 2014 11:54 pm ]
I just bought a Yamaha F70 and I am Highly Impressed with the Fuel Economy but I only have 6 Hrs on it. Does the Fuel usage get better after 10 Hrs?
Author:  Prodigy [ Sat Jul 19, 2014 5:23 am ]
Shouldn't change a lot.. What boat u have it on w what prop? Rpms?
Author:  Bad Boy [ Sat Jul 19, 2014 7:45 pm ]
18X42 Southfork Vented Tunnel Hull with Hydraulic Jackplate. I ran a 15 P Powertech Semicleaver and was hitting the Rev Limiter @ 6300. I just ordered a 13x17 P True Yamaha Semicleaver. That should keep me off the Rev Limiter and give me more Speed.
Author:  4Cody4 [ Wed Jun 20, 2018 11:06 am ]
Bump for an oldie. I was just doing some homework on re-powering with an outboard and this is about the best thread I've found so far.
Anybody have anything to add with an 1854 sized boat and a 70ish HP outboard?
Can anybody tell me if the boat (square chine) will slide less or more with the outboard than with the mm?
Thanks,
Author:  WestEndAngler [ Thu Jun 21, 2018 10:51 am ]
Author:  4Cody4 [ Thu Jun 21, 2018 11:28 am ]
That is helpful. I was planning to go run it a while and then possibly have some runners added to the bottom if it was skating bad. I’m hesitant to do that though just because there aren’t any builders near me.
Prowler is probably my closest option.
