It is currently Wed Mar 18, 2026 3:09 am
Reply to topic  [ 26 posts ]
 trailering bracket for a Gatortail
Post trailering bracket for a Gatortail
Any one got a pic of there trailering bracket set up on there Gatortail ? Thank you
Fri Feb 06, 2015 8:00 pm
Post Re: trailering bracket for a Gatortail
I believe Cottonmouth makes a nice one...
Fri Feb 06, 2015 8:21 pm
The issue I ordered a trailering bracket . I have an 2006 GTR . Endless I'm missing something it does not appear the new brackets are compatible with the older motors. I didn't think about it until after I ordered it
Fri Feb 06, 2015 9:15 pm
Corey's bracket is more like a transom saver for an outboard. Not the traditional bracket like what a GT comes with. I believe they're on his website.
Fri Feb 06, 2015 9:22 pm
Not much of anything on their web site
Gator tail
Fri Feb 06, 2015 9:29 pm
You can send an email to cottonmouthcustomboats@yahoo.com and we will send you an invoice. They are $130 plus tax and shipping and we have them in stock.
Corey Crochet
Cottonmouth Custom Boats, LLC
225-456-0930
Fri Feb 06, 2015 9:52 pm
There ya have it from the man himself. :)
Fri Feb 06, 2015 10:09 pm
Man I'm sorry I'm not interested in the 130$ transom saver. I allready have a GT trailering bracket. But I'm wondering if they are not compatible with the 2006 motor. If not I will just return it or have it modified. I usually strap down my motor but figured the bracket would be faster to secure the motor.
Fri Feb 06, 2015 10:45 pm
The GT bracket will work you just need to install the studs it hooks to.
Fri Feb 06, 2015 11:18 pm
I've got a friend that runs that little bracket thing on his 2006 Gtr....if that helps you any.
Ok great thanx. Gatortail is sending me the hardware for the beaket prolly should of just waited till it came in to see how it will work. Let me rephrase the previous statement. The cottonmouth transom saver is nice but I allready have a bracket.
Fri Feb 06, 2015 11:22 pm
Your going to have to drill and tap for the bolts that the bracket hooks to. In your picture I don't see the holes.
Sat Feb 07, 2015 5:54 pm
I had to install them on one if my motors. I drilled then used a helicoil kit.
Sat Feb 07, 2015 8:24 pm
Ok thanx that's what I was thinking. Just was not sure if it was a good idea to drill or not . What size helicoil bit did you use ? I'm still waiting for the hardware but I'd like to drill it out Tom if I can. Thanx yall
Sat Feb 07, 2015 9:18 pm
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Sat Feb 07, 2015 11:39 pm
Helicoil is mo betta.
Sun Feb 08, 2015 12:47 am
I've always had better luck drilling, tapping, and then Loc-tight'ing a helicoil in where I need threads. I've done it in thicker aluminum on boats too if you need a threaded hole to mount something.
Sun Feb 08, 2015 7:49 am
Those pegs with the pin to secure the bracket are a pain in the ass. We ground out a notch in it to and did away with the pin.
Sun Feb 08, 2015 8:44 am
Don't think you need to tap all the way threw go a few threads and tighten the dog shit out of it !
Sun Feb 08, 2015 8:56 am
Sun Feb 08, 2015 4:00 pm
X2. Never had that much of a hassle to want to change it
1548 SEA ARK with 2014 GTR 35
02 DURAMAX- MORE POWER, LESS SMOKE
Sun Feb 08, 2015 6:09 pm
Sun Feb 08, 2015 8:44 pm
I will wait for the hardware to get in to be sure of the size before I tap it / helicoil
Sun Feb 08, 2015 8:48 pm
Sun Feb 08, 2015 11:07 pm
If the trims holding down the bracket what's the purpose of the bracket ? Isn't the bracket supposed to secure the motor ? When you hit bumps and pot holes , your motors going to want to bounce. Won't that pin move around ?
Mon Feb 09, 2015 6:20 pm
1544 Cottonmouth w/ 23 Copperhead
Sun Jul 31, 2016 7:31 pm
