| trailering bracket for a Gatortail https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=59917 |
| Author: | Hernaja1 [ Fri Feb 06, 2015 8:00 pm ] |
| Post subject: | trailering bracket for a Gatortail |
Any one got a pic of there trailering bracket set up on there Gatortail ? Thank you |
| Author: | SETx Longtail [ Fri Feb 06, 2015 8:21 pm ] |
| Post subject: | Re: trailering bracket for a Gatortail |
I believe Cottonmouth makes a nice one... |
| Author: | Hernaja1 [ Fri Feb 06, 2015 9:15 pm ] |
The issue I ordered a trailering bracket . I have an 2006 GTR . Endless I'm missing something it does not appear the new brackets are compatible with the older motors. I didn't think about it until after I ordered it |
| Author: | SETx Longtail [ Fri Feb 06, 2015 9:22 pm ] |
Corey's bracket is more like a transom saver for an outboard. Not the traditional bracket like what a GT comes with. I believe they're on his website. |
| Author: | Old School [ Fri Feb 06, 2015 9:29 pm ] |
Not much of anything on their web site |
| Author: | thirdtimesacharm [ Fri Feb 06, 2015 9:52 pm ] |
You can send an email to cottonmouthcustomboats@yahoo.com and we will send you an invoice. They are $130 plus tax and shipping and we have them in stock. |
| Author: | SETx Longtail [ Fri Feb 06, 2015 10:09 pm ] |
There ya have it from the man himself. |
| Author: | Hernaja1 [ Fri Feb 06, 2015 10:45 pm ] |
Man I'm sorry I'm not interested in the 130$ transom saver. I allready have a GT trailering bracket. But I'm wondering if they are not compatible with the 2006 motor. If not I will just return it or have it modified. I usually strap down my motor but figured the bracket would be faster to secure the motor. |
| Author: | rob_E [ Fri Feb 06, 2015 11:18 pm ] |
The GT bracket will work you just need to install the studs it hooks to. |
| Author: | 270Handiman [ Fri Feb 06, 2015 11:18 pm ] |
I've got a friend that runs that little bracket thing on his 2006 Gtr....if that helps you any. |
| Author: | Hernaja1 [ Fri Feb 06, 2015 11:22 pm ] |
Ok great thanx. Gatortail is sending me the hardware for the beaket prolly should of just waited till it came in to see how it will work. Let me rephrase the previous statement. The cottonmouth transom saver is nice but I allready have a bracket. |
| Author: | jc [ Sat Feb 07, 2015 5:54 pm ] |
Your going to have to drill and tap for the bolts that the bracket hooks to. In your picture I don't see the holes. |
| Author: | rob_E [ Sat Feb 07, 2015 8:24 pm ] |
I had to install them on one if my motors. I drilled then used a helicoil kit. |
| Author: | Hernaja1 [ Sat Feb 07, 2015 9:18 pm ] |
Ok thanx that's what I was thinking. Just was not sure if it was a good idea to drill or not . What size helicoil bit did you use ? I'm still waiting for the hardware but I'd like to drill it out Tom if I can. Thanx yall |
| Author: | JLACOUR [ Sat Feb 07, 2015 11:39 pm ] |
| Author: | cb5331 [ Sun Feb 08, 2015 12:47 am ] |
Helicoil is mo betta. |
| Author: | SETx Longtail [ Sun Feb 08, 2015 7:49 am ] |
I've always had better luck drilling, tapping, and then Loc-tight'ing a helicoil in where I need threads. I've done it in thicker aluminum on boats too if you need a threaded hole to mount something. |
| Author: | dguidry [ Sun Feb 08, 2015 8:44 am ] |
Those pegs with the pin to secure the bracket are a pain in the ass. We ground out a notch in it to and did away with the pin. |
| Author: | Mudmotor Slayer [ Sun Feb 08, 2015 8:56 am ] |
Don't think you need to tap all the way threw go a few threads and tighten the dog shit out of it ! |
| Author: | Hernaja1 [ Sun Feb 08, 2015 4:00 pm ] |
| Author: | SNACKMIX [ Sun Feb 08, 2015 6:09 pm ] |
X2. Never had that much of a hassle to want to change it Sent from my iPhone using Tapatalk |
| Author: | rob_E [ Sun Feb 08, 2015 8:44 pm ] |
| Author: | Hernaja1 [ Sun Feb 08, 2015 8:48 pm ] |
I will wait for the hardware to get in to be sure of the size before I tap it / helicoil |
| Author: | dguidry [ Sun Feb 08, 2015 11:07 pm ] |
| Author: | Hernaja1 [ Mon Feb 09, 2015 6:20 pm ] |
If the trims holding down the bracket what's the purpose of the bracket ? Isn't the bracket supposed to secure the motor ? When you hit bumps and pot holes , your motors going to want to bounce. Won't that pin move around ? |
| Author: | mike3503 [ Sun Jul 31, 2016 7:31 pm ] |
