Boat Blind Ideas
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=61366
Author:  Jmm3 [ Sat Apr 18, 2015 9:17 am ]
Post subject:  Boat Blind Ideas
Im considering putting a more permanent blind on my boat. I have used pop ups for years and they just don't cut it for me. Im thinking about something like the phowler light marsh blind or something low profile which can also be removed during the off season. Im thinking about using conduit and bending/welding it kind of like the guy did in this article http://www.wildfowlmag.com/tactics/conc ... nd-hidden/. I would like to keep it low profile as possible due to the fact I have to get under a low bridge to get to my hunting spot...need to stay about level with the motor. Any ideas, pics, plans, etc. will be greatly appreciated.
Author:  grnhd [ Sat Apr 18, 2015 9:01 pm ]
Post subject:  Re: Boat Blind Ideas
I built one on my 1860 similar to the one in your link. But I don't like sides that I couldn't get into so made mine so that it has 3 "doors" on each side so that I can raise it up to get decoys out. Here is a link to something similar to what I did.
http://bustemboatblinds.com/
And here is a pic of mine. I've got lids on the top that open for each shooting hole.
Author:  Jmm3 [ Sat Apr 18, 2015 9:13 pm ]
Thanks!
Author:  Terraboat [ Sat Apr 18, 2015 10:17 pm ]
We sit in lightweight low profile turkey lounge chair. Easy to shoot in and easy to sleep in.
Author:  Jmm3 [ Sun Apr 19, 2015 7:52 am ]
I like the turkey chair idea. Makes sense. Do you have more pics of the blind build the frame? I get the concept but don't really understand how it operates or designed. Perhaps the dealer you mentioned has a website with pics of it? Thanks!
Author:  dguidry [ Sun Apr 19, 2015 8:39 am ]
I've thought of every conceivable boat blind configuration. I thought of a lightweight folding frame on pods that one deploys at the site and your boat just slips right in and out of it.
Author:  bobby_bates [ Sat May 02, 2015 1:50 am ]
I built mine using 3/4" EMT and a tube bender. The base is a "quick detach" with C-clamps attached to 1" square tubing. Used regular bimini hardware at the pivot points. Covered it all with burlap camo netting, and attached raffia grass to that. When down, it is even with the gunnel of the boat. Since it's custom built, you can make it as high/low as you want. Takes about 3 days to build. Here's a few pics
Author:  FSUDrew99 [ Tue May 12, 2015 9:58 am ]
Author:  3rd Coast Killer [ Tue May 12, 2015 2:37 pm ]
This guy seems to have it down with this duck killing machine.
Author:  brickgw [ Tue May 12, 2015 2:40 pm ]
Author:  dwbiggs [ Sat May 23, 2015 8:12 pm ]
Author:  Crazytrain20 [ Thu May 28, 2015 9:33 am ]
Mud Buddy shaggy blind with killer weed added to it!
Author:  Wilson [ Thu May 28, 2015 1:00 pm ]
How did you make the top covers?
Author:  buck72669 [ Mon Jun 08, 2015 3:05 pm ]
Here is mine.
Author:  buck72669 [ Mon Jun 08, 2015 3:07 pm ]
Folded down
Author:  Mallards Only [ Tue Jun 09, 2015 8:14 am ]
Silly question but why is there so much grass pointing inside your boat in the folded down position? Shouldn't it all fold up inside the frame with a little extruding the outer edges?
Author:  Wilson [ Wed Jun 10, 2015 2:30 pm ]
Good question. Maybe it's only attached to the frame on one side (top or bottom) and he rolls it up first, then drops the blind?
Author:  bobby_bates [ Sun Feb 14, 2016 8:44 am ]
Sorry Guys, I fell off the earth over here in Afghanistan. Here's some more pics of the blind I built.
Author:  DENNYEDWARDS [ Sun Feb 14, 2016 10:59 am ]
Heres ours before grassing, and after.
Author:  kneedeep81 [ Fri Sep 09, 2016 7:41 am ]
Where did you get the C-clamps?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Author:  bobby_bates [ Sun Sep 18, 2016 4:53 am ]
Bass Pro. They are actually (large size) rod holder clamps with tapped holes on the side and top. I paid $16 a piece for them.
Author:  Roostertail3 [ Sun Sep 18, 2016 7:16 am ]
Just built mine yesterday and going to put a camo net and raffia on it today. I have about $15 in materials not counting camo netting. I used one foot of angle iron ( 6" up front and 6" in rear). 3/4" EMT 2 couplings and some foam to protect my boat and gun.
Author:  Melnmo [ Mon Sep 19, 2016 6:16 am ]
I just finished a homemade fold down conduit blind for my boat. I saved a bit of money by making the brackets instead of purchasing the bimini hardware. I seriously considered a "permanent" type rigid blind but ultimately decided against it due to storage. My only storage option is a two car garage and there is not enough room to store a blind that has roughly the same outline as the boat when removed. Outside storage isn't an option if you want the fastgrass or other coverings to last more than a season. Also, taking the coverings on/off every season would be a pita.. so I ended up going with the folding blind. Mine comes off the boat with 4 bolts and folds flat against the wall in the garage with all the gras/coverings in place.
If I had a place to store a rigid blind then I probably would have gone that route. Lifting and then relaxing, folding and securing the fold down blind every hunt is a bit of work, especially when I'm hunting alone.
Author:  Roostertail3 [ Mon Sep 19, 2016 1:03 pm ]
Added the camo netting yesterday and will be dyeing the raffia and attaching later.
Author:  BERNIE255 [ Mon Sep 19, 2016 1:32 pm ]
Got my frame half way done, i used galvanized pipe as an inside sleeve to join my conduit together (had to grind the OD down a bit)
Gonna use hinges for the other part of the frame. Gonna be similar to buck72.
