It is currently Wed Mar 18, 2026 7:57 am
Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
 1999 GoDevil 1844 remodel
Post 1999 GoDevil 1844 remodel
I will update the thread as I make my updates to the boat.
Here is the foam under the front floor. It was saturated. In the second pic you can see the water that was just sitting under the foam. I got new foam from GD and will be replacing it.
Tue Sep 29, 2015 7:03 pm
Post Re: 1999 GoDevil 1844 remodel
Looking forward to seeing your project. I am starting a similar remodel with my GD 1844 too. Anyone just use pink foam home insulation to replace the original foam?
Sun Oct 04, 2015 5:24 pm
Did the old foam have some typenof fiberglass facer on it?
It looks like PolyIso.
Sun Oct 04, 2015 7:26 pm
Mon Oct 05, 2015 10:35 pm
The old foam did have some kind of layer on it. The foam was 16 years old. I got my new foam from go devil. I probably will get saturated again but I take care of my stuff. Keep it out the rain, etc. I currently have an experiment going. I submerged 3.7 oz of the new foam in a bucket of water. Completely under water with bricks holding it down. I'm gonna see how long it takes to saturate it. Btw my old foam from the floor weighed 197#. Currently working on the blind and electrical. Plan to paint but that may wait till after the season.
Tue Oct 06, 2015 7:56 pm
Did Go Devil tell you what type of foam they sent you?
The old foam looks like PolyIsocyanurate commonly used in commercial roofing applications.
It is pretty water resistant, but if held under water(like your test) will absorb and it almost impossible to dry out.
Wed Oct 07, 2015 8:32 am
No but coco did tell me he's tried all different kinds of foam. They all soak up water over time. But he believes in selling coast guard approved boats regarding safety for non commercial use. So in some of these boats you have to use foam under the floor I guess. He did say it's basically hearsay on the forums regarding closed cell foam not soaking up water.
So after 24 hours completely submerged, the foam now weighs 5.5 oz which is a 1.8 oz increase (49%). This is about a 10"x8" block
Wed Oct 07, 2015 7:14 pm
Wed Oct 07, 2015 7:38 pm
Weighed again--48 hours later. It's still weighed 5.5 oz. So no weight gain over the last 24 hours. Remember this is completely submerged
Thu Oct 08, 2015 7:11 pm
Why don't they/ doesn't someone just vacuum seal the foam before putting it in the boat?
When I take the foam out of my boat I'm just gonna leave it out but I know some people like it in there. Seems like vacuum sealing it would keep the water out
Thu Oct 08, 2015 7:56 pm
Fri Oct 09, 2015 4:26 am
No I have no doubt it will. But if it takes 3 years then I'll be happy
Fri Oct 09, 2015 4:49 am
Here's the link to my GD1644 project from a few years back. It might give you a few pointers for your build.
viewtopic.php?f=4&t=13272
Fri Oct 09, 2015 8:04 pm
thanks chris
thats a sweet rig. im hoping my paint job comes out that good. im dreading the prep honestly
Fri Oct 09, 2015 10:06 pm
So after 12 days submerged, total weight is 6.3oz which is a 79% increase in weight. The foam was not completely saturated as it was when I pulled the original 16 year old foam out. I think ill be ok for the next few years as long as it doesn't sit in water for extended periods.
Sun Oct 18, 2015 6:27 pm
Tue Oct 20, 2015 1:11 pm
Been really busy these last few weeks. Won't be ready for opening weekend but that's ok Bc its still 80* here. But here's some progress from today. Plan to work on electrical tomorrow.
Sat Oct 31, 2015 4:22 pm
Here's some grass I threw up there to see how it looks. I haven't secured it yet. Plus the beginning my wiring. I used marine grade duplex wiring. New led navigation lights
Hopefully switch panel will go in tonight or tomorrow. Will work on securing the grass during the week.
Tue Nov 03, 2015 7:42 am
All I have left to do is paint. I'll be doing that after the season. Here's my new switch panel, electrical wires, battery box, new bilge, blind
Sat Nov 07, 2015 7:47 pm
Looks good man. My boat blind got destroyed today by a dog that's been waiting a year to chase a duck.....
Sat Nov 07, 2015 8:17 pm
Finally got the painting done
Fri Oct 14, 2016 2:19 pm
Fri Oct 14, 2016 2:20 pm
I want to replace the floors with something thicker and remove the foam for good from the floor. What gauge is everyone putting in their boats who has replaced the floor? I was quoted $160s for 1/8" diamond aluminum floors.
Fri Oct 14, 2016 2:22 pm
Fri Oct 14, 2016 4:44 pm
No cut to fit. I will screw/rivet it down
Is 1/8" overkill?
Fri Oct 14, 2016 4:49 pm
As easy as it is to replace the foam I would leave it , it also supports the hull a little
driving a gd in ur lake
and i aprove this message
Fri Oct 14, 2016 7:28 pm
Fri Oct 14, 2016 9:06 pm
I replaced the foam beginning of last season. I'm constantly worried about it getting saturated again. Anyway I'll be taking it out but the floors are too thin.
Flint do you know how thick I need to go to give some support after the foam is out?
Sat Oct 15, 2016 8:12 am
I would do 100. My dad has 80 and it's enough, but barely. He doesn't have as much open floor with the boxes he's got in his boat. It would be a bit thin if he didn't have all that extra bracing.
Sat Oct 15, 2016 9:51 am
Yeah it does anything that fills a void does offer some support
Sat Oct 15, 2016 10:48 am
Sat Oct 15, 2016 11:24 am
Sat Oct 15, 2016 11:27 am
Ok if you say so
Sat Oct 15, 2016 8:38 pm
Sat Oct 15, 2016 8:48 pm
But it can't pop rivets because it won't add any support
Sun Oct 16, 2016 3:01 pm
Sun Oct 16, 2016 5:14 pm
I'm just waiting to hear how many plastic bottles it will take to fill the void and offer flotation.... It's all the rage I hear.
Wed Oct 19, 2016 7:03 pm
*facepalm*
#cffitr
Wed Oct 19, 2016 7:22 pm
Lol
Wed Oct 19, 2016 9:04 pm
if you are looking to lay a floor without foam underneath, you will need a minimum of .125". However if you are a bigger guy, you will still see the floor give a little. If you want NO give, you will need the .190" diamond plate.
I've done this on 2 of my boats recently and learned the hard way that .100" doesn't work for flooring without foam or a lot of supports under it.
Thu Oct 20, 2016 12:10 pm
