Marsh Intercoastal Boat
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=65003
Author:  jred00 [ Wed Dec 16, 2015 5:14 am ]
Post subject:  Marsh Intercoastal Boat
New to this arena and would appreciate your insight.
My house backs up to marshland that is tidal in Florida. About 500 feet through the marsh I can reach the intercoastal waterway.
I'd like to put together a boat that can hunt ducks/fish and be able to move the best at low tide. There are definately logs and stumps in the marsh, but I suspect I'll be able to discover a satisfactory path after a few attempts. Once in the intercoastal I may travel 5-10 miles to hunt. I'm going to launch the boat from my backyard with a golf cart (boat cant be too heavy)
I'm looking at an alumacraft 1542 (210 lbs) with a 23 hp beavertail long tail motor. I suspect the trips will generally be two adults for hunting. Does this seem like a reasonable set up, or should I be looking to buy a different set up. Completely new to this. Thanks
Author:  TexasGDvl13 [ Tue Mar 22, 2016 6:03 am ]
Post subject:  Re: Marsh Intercoastal Boat
Depends on how fast you want to go and in the intercoastal it's going to suck with that long tail. If you aren't making a very long run and you just want to put around you will be alright but if I were you and it was in my budget I would look into a surface drive.
Author:  Russ [ Tue Mar 22, 2016 8:53 am ]
Go 16 ft with the longtail, or a bit wider with a surface drive. 1644 w/lt, or 1546-48 w/sd. What you listed would be fine for your expectations, but once you get to deeper water, the extra lift will let it run higher, and be a tad more stable. That's a long run with a longtail, but it'll do the job. Figure your budget, and go from there.
Author:  brstanle [ Tue Mar 22, 2016 9:33 am ]
Longtails are great machines and cost effective but they're a workout. I would try finding someone around you with a Longtail setup that you can try so you know what you're getting into beforehand.
Author:  jakehawk9 [ Tue Mar 22, 2016 9:45 am ]
Author:  Will [ Wed Mar 23, 2016 4:38 am ]
Where are you at in Florida?
