It is currently Wed Mar 18, 2026 9:42 am
Reply to topic  [ 14 posts ]
 Bow mount trolling motor for 1860
Post Bow mount trolling motor for 1860
Will a 55 lb thrust 12 volt be enough? Mainly will use for controlled drifts at coast or rivers. Would prefer not to go 24 volt. Would have a dedicated battery. Will this work?
Fri Jan 08, 2016 12:38 pm
Post Re: Bow mount trolling motor for 1860
I have a 12 volt 55lb on my 1854 and it is okay, as long as there is no vegetation. I went 12 volt because I did not plan on fishing that much. If you are not worried about the added weight a 24 volt system would be a lot better
Fri Jan 08, 2016 12:55 pm
I run a 55lb 12v Minn Kota Edge bow mount on mine and it does fine. I can fish all day on a fresh charge. That's thru vegetation and river currents as well.
Fri Jan 08, 2016 3:15 pm
I've got a 12v 55lb power drive. I run two dedicated group 29 deep cycles because I hate my batteries dying. I've been toying with the idea of a 24v setup, but don't NEED to. If I fished current in rivers I'd go bigger. This is on an 1848.
Every day I'm paddlin'
Fri Jan 08, 2016 6:24 pm
I have an 1854 and I had a 55lb 12v on it. It wasn't enough for me. A long day of fishing grass, wind, and current would kill my battery. Two days in a row of fishing(12 hrs of charge time between the two) forget about it! So, I started looking around for a 24v. Came across a smoking deal on a minn Kota 101lb 36v (couldn't pass it up)! Wired it so I have my cranking battery in series to get the 36v. All I can say is its an animal! It goes through grass mats and lillies just as good as my big motor! Lol! Is it overkill? . . . Yes. But do I like it? . . . HELL YEA!
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Fri Jan 08, 2016 6:49 pm
Looking at a riptide 55lb 12 volt bow mount. Anybody have the quick detach base? Do you like it? Should I just get 2 batteries if I want to fish multiple days in a row?
Sun Jan 10, 2016 10:43 am
I've got the power drive which is the same style as the riptide st. I've got minn kota's cheap (I think I paid $40) quick detach base. It works for me quite well.
Sun Jan 10, 2016 10:54 am
Sun Jan 10, 2016 11:25 am
viewtopic.php?t=65319
Sun Jan 10, 2016 3:51 pm
Sun Jan 10, 2016 6:41 pm
For the guys with go devil boats did you go with 42 or 52 inch shaft? Is the 42 enough for you not to have to bend down too far to turn or adjust?
Wed Mar 30, 2016 8:13 am
Get the longest one you can get, they're very easy to cut down if it's too long but you have to replace the entire shaft and splice wires if it's too short.
Wed Mar 30, 2016 10:20 am
where you located? I have a bow mount 70lb minn kota edge new in box that I cant use. give you a deal. im in Northern IL.
Wed Mar 30, 2016 10:52 am
MMT Moderator
I run 2 batteries for my Minn Kota Ipilot they last 1/2 a day
GTB 1860 w/ 2019 GTR40XD-HO
Wed Mar 30, 2016 12:38 pm
cron
