It is currently Tue Mar 24, 2026 12:47 pm
Reply to topic  [ 5 posts ]
 New Bowfishing Setup
Post New Bowfishing Setup
Decided to make the switch from the 4" LEDs to some large reflector warm white LEDs. While I was at it I figured why not redo my rails for the front.
Progress is coming along. Have two more mounts to shorten so I can add two lights to the front then have to hard mount the lights with bolts and to nuts. Everything is zip tied right now so I can adjust the locations of each light.
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Fri Mar 04, 2016 1:54 pm
ImageUploadedByTapatalk1457121389.231982.jpgImageUploadedByTapatalk1457121399.414843.jpgImageUploadedByTapatalk1457121409.886700.jpg
Gonna get its first test tomorrow night
"The internet"
Fri Mar 04, 2016 1:56 pm
Post Re: New Bowfishing Setup
Interested in your review of old vs new..
Sat Mar 05, 2016 8:57 pm
Old setup (14 square 27w LEDs with amber tint).
Pros:
- lights are relatively cheap. Normally bought through Amazon with prime shipping.
- the amber tape helped cut the glare from the white LEDs.
- runtime was normally 6-7 hours before dimming noticeably.
Cons:
- not all were ordered from same place so pattern and light quality were not identical.
- flood pattern just wasn't wide enough for my liking. There were always shadows where the beams crossed which led to all my "expert" friends constantly trying to adjust them up/down, left/right.
Killed a lot of fish over the 27's but wanted to try something different.
New setup (10 - 30w warm white 120 degree floods)
Pros:
- 120 degree flood pattern is nice. Lights are spaced further apart with no shadows in between.
- warm white color took a little getting used to compared to the white led with Amber lens, but they did penetrate the water enough to see fish in dirty water.
- cheaper than the 50w lights with really not much noticeable difference. When I bought these I bought 1 to try and we mounted it next to 1 of my friends 50w. The difference to me wasn't enough to validate the extra cost per light.
Cons:
- runtime was between 5-6 hours last night before dimming. Not positive batteries were both at 100% before the trip. Will test that out further.
- not sure how tough the lenses are on these. No casualties last night but will keep an eye on them especially from kicked up rocks from my tires while driving
- mounts are flimsy 1/8". Debating on making some stronger mounts.
First trip was a success. 3 man trip
15 reds
5 sheepshead
4 black drum
1 nice sized gar
"The internet"
Sun Mar 06, 2016 9:44 am
Very nice! I actually just got done redoing mine to go with 12 volt led. I did a combo with the 27 watts (the ones gator tail sells with their rails) and 2 (1 each side as the last lights of the row ) 40 watt large reflectors. Planning on trying it out next weekend (no rain so water should be clear). I tested it yesterday for run time, had the lights running with the trolling motor running on low as well off of 2 parallel deep cycles. I was ready to go to bed when I turned it off. It ran 4 hours and still had 62% charge.
HOTSAUCE170 wrote:
Sun Mar 06, 2016 10:35 am
