| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| 18x52 performance what to expect. https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=65904 |
| Author: | jtwilliams [ Fri Feb 19, 2016 6:08 pm ] |
| Post subject: | 18x52 performance what to expect. |
18x52 performance?? has a square chine, crimped sign. cat walks. 4' front deck, built in 12gallon tank, floor, rear box to sit on, has the modified hunt deck. i have a 35gtr with calens heads and cam along with stainless works muffler. give me some expected numbers loaded say 3 peep and a dog and empty!!! |
| Author: | jtwilliams [ Fri Feb 19, 2016 7:22 pm ] |
| Post subject: | Re: 18x52 performance what to expect. |
anybody |
| Author: | brycecheramie [ Fri Feb 19, 2016 8:00 pm ] |
how can anyone answer that, accurately? |
| Author: | jtwilliams [ Fri Feb 19, 2016 9:13 pm ] |
im not looking for an exact number. im just wondering if it should run 30+ unloaded. and 27+ loaded |
| Author: | brycecheramie [ Fri Feb 19, 2016 9:24 pm ] |
well, most boats bigger than the one you're talking about, with the mods you have, run those speeds. So, its safe to say you can expect those speeds too. Considering that there are no hooks in the hull |
| Author: | jtwilliams [ Fri Feb 19, 2016 10:40 pm ] |
yea reason im asking is he says its running 31 with a prodrive stage 1, and says the transom angle is 20degrees which i thought was for a gt. just want to make sure this make sense. i didnt know if a pd would run that on that transom angle. so he swears its 20degrees. i want to make sure |
| Author: | brycecheramie [ Fri Feb 19, 2016 10:42 pm ] |
| Author: | JD145 [ Sat Feb 20, 2016 8:26 am ] |
| Author: | jtwilliams [ Sat Feb 20, 2016 10:44 am ] |
i guess im just scared of that 18'. haha years ago i never wouldve dreamed of running a boat that big. "always was thought to be a barge. that would get stuck so easy being so heavy ect" no it seems 18' is the norm. guys are running in the 30's ect. i do see that they may only run 30 and a 17' run 32 but when you load 4 guys and dog. the extra foot shines. |
| Author: | Quack N Stack [ Sun Feb 21, 2016 8:21 pm ] |
Mines a 18x60 and it has gone through just about everything I can find to put it through. Only got it stuck where I was absolutely fuked once. But it handles mud like a champ and don't struggle at all. Does 28-29 empty and around 25 with a 4 man 6 dozen decoy hunt load. 18 ft is what must people run. Although the next boat I buy will more than likely be a 20' hull. |
| Author: | Will C [ Sun Feb 21, 2016 8:43 pm ] |
Lots of ifs. It should be a strong motor and carry a load good. I would not expect a screamer on top end with a stock carb |
