It is currently Tue Mar 24, 2026 6:46 pm
Reply to topic  [ 9 posts ]
 LED strip lights
Post LED strip lights
So ive got these cheap ebay strip lights to put inside my hull. Well i have a textured hull which is great and all until you try to stick crap to them. I have seen where people just use superglue as a filler/adhesive. Anyone have some tips for mounting? Im sure im not the first to have this problem. Thks for anything yall can throw my way
Tue Feb 23, 2016 1:51 pm
Post Re: LED strip lights
clear silicone
Tue Feb 23, 2016 2:02 pm
I use rtv
Tue Feb 23, 2016 2:09 pm
Gum. Don't overthink it, though. Double sided tape, folded over gorilla or duck tape, or silicone. The clear works good in case you get it over the light, it won't obscure light like the blue marine will.
Tue Feb 23, 2016 2:33 pm
Im probably going to go with clear silicone. more than likely im overthinking it. 1553 Havoc boat btw so 2 strips will do me fine. thanks again fellas
Tue Feb 23, 2016 3:21 pm
I have never had silicone stick to anything for very long but the lights are pretty light. I would use 3m double sided tape if the regular glue on the lights won't work
Tue Feb 23, 2016 6:59 pm
My lights have been stuck with silicone for 10 months now. Still stuck
Tue Feb 23, 2016 7:03 pm
Rivet in aluminum angle. Stick it to the top section facing down. Gives off a lot of light and comes out very clean
Gator Trax 1750HD powered by a Mud Buddy 5500 BAMF
-Unbaffled VooDoo
-Gator Glide G2 with base
-Wet Sounds Stealth 10 Ultra V2
-Green LED Courtesy Lights
-15" Combo LED Light Bar
Tue Feb 23, 2016 8:31 pm
Industrial strength Velcro strips
Crisis defines character
Tue Feb 23, 2016 9:55 pm
