It is currently Fri Mar 27, 2026 2:18 am
Reply to topic  [ 8 posts ]
 20mph out of 35hp mudbuddy hd sport on 16x48 old flat
Post 20mph out of 35hp mudbuddy hd sport on 16x48 old flat
Hey guys im new to MMT, I have a question on my rig. I recently replaced my 18hp mud buddy hd mini with a 35hp hd sport with power trim, with the old motor I would get 20mph, with the new one I was getting 22mph until I had some small pods put on and bent my scag pretty badly, I heated the scag and bent it back close to where I think it should be and took it for a spin tonight (just me and my dog and some light fishing gear) I only got 20mph out of it running a little over 4k rpms and it pulled hard trying to turn the boat left (guessing scags not quite where it should be). What do you guys think? shouldn't I get a little more speed out of it? The boat is a 1971 ouachita 16x48 and is a very light boat.
Thu Apr 07, 2016 9:25 pm
Post Re: 20mph out of 35hp mudbuddy hd sport on 16x48 old flat
Pods are fuckin you up man. Creating drag most likely. Or sending turbulent water to the prop. Idk about your Skeg* post some pics up of the damages
Fri Apr 08, 2016 9:48 am
Transom Height?
You have a tall transom motor on a short transom boat? Or Vice Versa?
Kool-Aid Brigade
www.southernfowler.com
Fri Apr 08, 2016 10:00 am
trimmed too high?
Fri Apr 08, 2016 11:16 am
I'd also bet with that old of a boat, you've got some dents in the bottom that are slowing you down too!
Fri Apr 08, 2016 5:23 pm
A worn prop could also be the issue
Mon Apr 11, 2016 1:26 pm
I found out I was missing over an inch on my prop so got a new one, I am going to try it out tomorrow and see what that gets me, thinking about just getting a different hull. mine is in good shape with very few small dents on the bottom but I feel a wider boat will help, and I do believe the pods are messing it up, the reason I put them on there is because I had a 18hp mb hd mini and could go through double the stuff as I can with the 35 hp. Thanks for all the tips, this is a great site!
Mon Apr 11, 2016 8:47 pm
So, why are pods on there anyway?
They are probably hurting your speeds too.
Also, it is almost 100% all your props fault. Missing even 1/4" can hurt you.
you will see a huge improvement
Mon Apr 11, 2016 9:05 pm
