It is currently Tue Mar 24, 2026 6:52 pm
[ 7 posts ] |
teammarshmafia
Joined: Tue May 14, 2013 2:18 pm Posts: 478 Location: southeast, Louisiana
 Dual prodrive guys
Got a quick question for yall! What is the distance between the 2 motors when mounted on the transom. Tried to search it only to find nothing. Called prodrive and the guy I talked to said he thinks it's 40" center to center.
Getting a rig built that will eventually have duals on it. Also, if yall have any suggestions for making it easier to go from a single tiller motor to dual center console let's hear it!
Sent from my SAMSUNG-SM-G890A using Tapatalk
_________________ Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom Jus nut up and grab a handful of throttle
| Tue Apr 19, 2016 6:28 am |
banded-mallard
 Re: Dual prodrive guys
As long as the lower spinning around clears the other motor, you should be fine
| Tue Apr 19, 2016 8:41 am |
teammarshmafia
OK would I benefit more from having them farther from each other or as close as I can get em to each other
| Tue Apr 19, 2016 4:27 pm |
Will
I would put them as far apart as possible, less disturbance between them I would think. Probably really doesn't matter though.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Tue Apr 19, 2016 5:42 pm |
JLACOUR
Joined: Wed Jan 14, 2009 8:18 pm Posts: 4915 Location: Lake Jackson, TX
Disturbance between motors is just as important as disturbance from the sides of the boat. If Prodrive says 40", then I would go 40.
_________________ 37 PD EFI FPR 18x48 Tiller SOLD -- 36 PD EFI FPR 18x48 Stick Steer SOLD -- 27 PD FPR 16x36 Skiff
| Tue Apr 19, 2016 6:31 pm |
Will
| Wed Apr 20, 2016 5:33 am |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
Just measured my boat, 23.5" inside to inside on my factory installed PD duals.
_________________ 24x60 Dual Prodrives
| Thu Apr 21, 2016 5:52 pm |
[ 7 posts ] |
