| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| Dual prodrive guys https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=66613 |
| Author: | teammarshmafia [ Tue Apr 19, 2016 6:28 am ] |
| Post subject: | Dual prodrive guys |
Got a quick question for yall! What is the distance between the 2 motors when mounted on the transom. Tried to search it only to find nothing. Called prodrive and the guy I talked to said he thinks it's 40" center to center. Getting a rig built that will eventually have duals on it. Also, if yall have any suggestions for making it easier to go from a single tiller motor to dual center console let's hear it! Sent from my SAMSUNG-SM-G890A using Tapatalk |
| Author: | banded-mallard [ Tue Apr 19, 2016 8:41 am ] |
| Post subject: | Re: Dual prodrive guys |
As long as the lower spinning around clears the other motor, you should be fine |
| Author: | teammarshmafia [ Tue Apr 19, 2016 4:27 pm ] |
OK would I benefit more from having them farther from each other or as close as I can get em to each other Sent from my SAMSUNG-SM-G890A using Tapatalk |
| Author: | Will [ Tue Apr 19, 2016 5:42 pm ] |
I would put them as far apart as possible, less disturbance between them I would think. Probably really doesn't matter though. |
| Author: | JLACOUR [ Tue Apr 19, 2016 6:31 pm ] |
Disturbance between motors is just as important as disturbance from the sides of the boat. If Prodrive says 40", then I would go 40. |
| Author: | Will [ Wed Apr 20, 2016 5:33 am ] |
| Author: | Crews [ Thu Apr 21, 2016 5:52 pm ] |
Just measured my boat, 23.5" inside to inside on my factory installed PD duals. |
