It is currently Tue Mar 24, 2026 2:01 pm
Reply to topic  [ 7 posts ]
 Dual prodrive guys
Post Dual prodrive guys
Got a quick question for yall! What is the distance between the 2 motors when mounted on the transom. Tried to search it only to find nothing. Called prodrive and the guy I talked to said he thinks it's 40" center to center.
Getting a rig built that will eventually have duals on it. Also, if yall have any suggestions for making it easier to go from a single tiller motor to dual center console let's hear it!
Sent from my SAMSUNG-SM-G890A using Tapatalk
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Tue Apr 19, 2016 6:28 am
Post Re: Dual prodrive guys
As long as the lower spinning around clears the other motor, you should be fine
Tue Apr 19, 2016 8:41 am
OK would I benefit more from having them farther from each other or as close as I can get em to each other
Tue Apr 19, 2016 4:27 pm
I would put them as far apart as possible, less disturbance between them I would think.
Probably really doesn't matter though.
Tue Apr 19, 2016 5:42 pm
Disturbance between motors is just as important as disturbance from the sides of the boat. If Prodrive says 40", then I would go 40.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Apr 19, 2016 6:31 pm
Wed Apr 20, 2016 5:33 am
Just measured my boat, 23.5" inside to inside on my factory installed PD duals.
24x60 Dual Prodrives
Thu Apr 21, 2016 5:52 pm
