It is currently Tue Mar 24, 2026 3:38 pm
Reply to topic  [ 6 posts ]
 NEED ADVICE
Post NEED ADVICE
Gonna put gator glide on my phowler 17/48. My Q is how are y'all lifting your boats. I have cherry pickers, and was gonna use them. My concern is the handles welded on the front and back aren't strong enough to support the weight. Any advice will be appreciated. Thanks in advance!!
Sun Apr 24, 2016 6:18 pm
Post Re: NEED ADVICE
Guy I know used 4x4s under his catwalks and picked it up.
Sun Apr 24, 2016 6:21 pm
I hung my 1850 phowler prowler by the handles. Motor was not on the boat. I kept some saw horses under it just in case something failed. The saw horses were very close to the bottom of the boat, but not touching it.
Sun Apr 24, 2016 6:22 pm
I picked my 16x60 godevil boat up by the handles front and back (2x now). The motor was on it. I just removed everything that was added weight (gas can, batteries).
Sun Apr 24, 2016 6:44 pm
Only way to do it.... And this is rigged off the two handles in the back.
-Custom pool noodle
-stage 4 water wings
Sun Apr 24, 2016 7:00 pm
However you do it, put something under the boat with you. I use a 30 gal drum, 2 5 gal buckets full of sand with a 8' 4 X 4. If it does come down you can get out. probably wont but make sure you're safe "first"
http://www.gatorglide.com/
gatorheads@comcast.net
Mon Apr 25, 2016 6:59 am
cron
