New backyard build
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=66815
Page 1 of 2
Author:  rubbinisracin [ Mon May 09, 2016 12:16 pm ]
Post subject:  New backyard build
1854 (actually 18 ft 4 in)
5083 4mm(0.156 inch) aluminum one piece hull
5052 decking (0.080 inch)
single taper chine
Center console with center mount Uflex ram
GTR 37 EFI stock
2 Rule 1500 GPH bilge pumps (I don't want water in the boat)
12 gallon gas tank
2 batteries
6.5 foot rake
72 inch beam at widest spot measured to outside of gunnel
Based on my materials the hull should weigh somewhere around 580-600 lbs. But I never actually weighed it.
Post subject:  Re: New backyard build
More photos
Author:  rubbinisracin [ Mon May 09, 2016 12:17 pm ]
more
Author:  rubbinisracin [ Mon May 09, 2016 12:18 pm ]
more
more
Author:  rubbinisracin [ Mon May 09, 2016 12:19 pm ]
more
Author:  rubbinisracin [ Mon May 09, 2016 12:20 pm ]
more
more
Author:  rubbinisracin [ Mon May 09, 2016 12:21 pm ]
last few
Author:  rubbinisracin [ Mon May 09, 2016 12:22 pm ]
last one
Author:  rubbinisracin [ Mon May 09, 2016 12:31 pm ]
I made the picture quality low so they would upload easy...may be too low but you'll get the idea.
I ran it yesterday for the first time with my wife, baby, dog, 10 gallons of gas, 2 batteries, trolling motor and me in and it felt great. Much more stable than my last boat (1542 with 23 hp hyperdrive). I didn't really get to play with it much cause I didn't have a lot of time and we had the baby on board. But at one point I tacked it up a bit and it was running 25 and some change (deep water). I had to trim it pretty high to get that but it seemed to like running higher on the trim than my last boat. It just started to make a hum noise with the prop on the water. I think if I go play with it some more I can figure it out better and maybe get a little more speed, I was running 4080 rpms when I was touching over 25 mph so if I keep going up with the trim I might could run the rpms a little higher and get some more speed. I was hoping to see a little closer to 30 but if 25 is all I get thats fine.
Do these motors pick up much as they break in or is it fairly negligible? I might gain a little then.
Author:  SETx Longtail [ Mon May 09, 2016 2:50 pm ]
Should gain a mph or two when the engine gets a little time on it. Wearing the prop in may gain you a little as well.
Author:  rubbinisracin [ Mon May 09, 2016 3:10 pm ]
That would be nice. I thought about playing with the weight distribution some too but I don't really have much room to move stuff since I pretty specifically placed the batteries and gas in the CC. It appears to draft about 4.5 -5 inches in the rear at the deepest and tapers up from there. I thought that was pretty good for the amount of stuff I have in the boat (2 batteries and 10 gallons of gas).
Author:  rubbinisracin [ Tue May 10, 2016 7:20 pm ]
Also, fyi, that gator glide is the slickest shit I have ever dealt with....you should have seen me try to load my boat at the ramp. I gotta figure the trick out for that, it won't say on the trailer bunks long enough to get up there and hook it down. But it's gonna be real nice crossing the Beaver dams and such.
Author:  SETx Longtail [ Tue May 10, 2016 8:54 pm ]
Frog has a solution for that. He's posted the pic a bunch of times of a roller that sticks up an inch or so behind the transom. The boat will float over it while unloading (or take it off) and when you load up the boat rolls over and falls in front of the roller holding it in place so you can hook up the winch.
Check his website, might be something there on it.
Author:  SCmudder7071 [ Tue May 10, 2016 8:59 pm ]
Damn fine job. Especially from a east coast guy.
Author:  brycecheramie [ Tue May 10, 2016 9:00 pm ]
Author:  SETx Longtail [ Tue May 10, 2016 10:42 pm ]
Bingo, thanks!!
Author:  rubbinisracin [ Wed May 11, 2016 5:07 am ]
Thanks SC mudder!
That roller is a great idea I'm making some trailer mods now so that will be one of them.
Author:  steinb3rg [ Wed May 11, 2016 5:22 am ]
Nice boat. Where'd you get the ideas for the inside layout?
Author:  rubbinisracin [ Wed May 11, 2016 5:36 am ]
I've been following this site since 2013 and when I see something someone did I save it. So it took me 2 or 3 years to plan the boat and 2 or 3 months to build it. This site is great advertising (or bad if you got problems) , I went with the gatortail because of this site and the gatorglide. As far as that layout I knew it was gonna be my hunting, fishing, bowfishing, and hangout boat for the summer so I tried to make it work for all. The side gun boxes were also put in for strength and they really aren't in the way so it's free space.
Author:  steinb3rg [ Wed May 11, 2016 5:45 am ]
It's a great design. You have good taste.
Looking at yours is like seeing mine in nat gear camo. Haha
Author:  rubbinisracin [ Wed May 11, 2016 5:50 am ]
Haha I have that picture saved it was definitely one of my inspirations
Author:  steinb3rg [ Wed May 11, 2016 5:57 am ]
Well I'm glad it was useful. Only thing I would've changed about mine after the fact is the width which yours is 54 so you get that little bit extra room.
I hope you get as much use out of yours that I do mine but be prepared to throw money at it. If a part can break, it probably will.
Author:  rubbinisracin [ Wed May 11, 2016 6:01 am ]
Well I appreciate it it's a huge difference compared to my 1542. I fully expect to have to throw some money at it, hell at this point I've thrown a lot of money at it anyways to get it here.
Author:  OwenDickeson [ Wed May 11, 2016 9:33 am ]
Author:  rubbinisracin [ Wed May 11, 2016 9:48 am ]
Yea I thought about that but it seemed sketchy...
Author:  willett [ Wed May 11, 2016 6:10 pm ]
Boat looks awesome, Great job!
Author:  rubbinisracin [ Wed May 11, 2016 7:18 pm ]
Really appreciate it. Definitely got some inspiration from your work.
Author:  rubbinisracin [ Sat May 14, 2016 4:51 pm ]
Ran today with my old man, his German Shepard, and my dog, with a slight breeze at our back we were able to hit 26.7 mph at 4050 rpm in deep water in some smooth sections. If I trimmed any higher from there to gain rpm it lost speed. It took a while to hit that, we pretty consistently ran 23 -24, but it was a bit choppy from the wind and all the boats.
Author:  rubbinisracin [ Sun May 15, 2016 3:12 pm ]
Ran again today, just me and my dog, we almost hit 29 (28.8 @ ~4200 rpm) but consistently ran 27, pretty much just deep water. So it appears that with added weight comes a relatively significant speed drop. It was also a little calmer today so the water was a little smoother.
Author:  cupped up [ Tue May 17, 2016 1:00 am ]
Good lookin' hull.
Author:  rubbinisracin [ Tue May 17, 2016 5:01 am ]
Thanks, I'm very pleased with it. Once I get some more hours on it I'll post a review in the review section with more detailed specs for those interested.
Author:  Walkers Bay Synd [ Tue May 17, 2016 5:16 am ]
Dam....do you spit polish that garage floor.
Don't think I spotted one tool out of place or loose off cut nothing.
Author:  rubbinisracin [ Tue May 17, 2016 5:23 am ]
Haha it actually happens too look better in those pictures than it did most of the time during the build. But that said I am a little neurotic about clutter, however on the other hand I hate those garages that look like an interior decorator put them together and all the guy does in it is polish his motorcycle.
Author:  swampfox1 [ Thu May 19, 2016 7:04 am ]
nice rig. where are your home waters in nc. I don't live to far from you. if u want to ride sometime let me know.
swampfox aka Phil
swampfox aka Phil
Author:  rubbinisracin [ Thu May 19, 2016 10:20 am ]
Mainly Falls lake and Jordan. But I usually am in water all over the state throughout the year. The Durham end of Falls is where the mud motor is pretty much a must. Where do you typically put in at?
Author:  Zeek569 [ Thu May 19, 2016 1:27 pm ]
If you would like to see some gains in speed with out voiding your warranty. exhaust and send your prop to la prop then you should reach the 30 mph mark you wanted
Author:  rubbinisracin [ Thu May 19, 2016 1:38 pm ]
I just ordered a spare prop from Calen, he suggested the MudBuddy Big Blade. Maybe when I get that one I can send my 3 blade out to make me a summer time speed prop. (I would assume that the 3 blade will have a better chance of being the faster one based on the threads I have read)
As for the exhaust, I thought it would be nice to get a deeper sound out of it so it doesn't sound like I hanging out next to a lawn mower all day. I didn't really think I would expect much gain though from any of the major exhausts out there on a stock motor. Those Voodoos look cool but the idea of going quieter is appealing too, maybe the BPS Q? All of them are a bit more pricey than I really want but maybe I'll put one on the wish list.
Page 1 of 2 All times are UTC - 6 hours
