| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| Floor removal https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=67290 |
| Author: | va_quack_smacker [ Thu Jun 23, 2016 5:45 pm ] |
| Post subject: | Floor removal |
I have a lowe 1752 Roughneck and i want to remove the floor to take out the wet foam. i am having a problem trying to figure out how to remove the floor and the panels that line the gunwall. i was wondering if anyone here has done it before or has any tips on how to do it the most painless way if there is any. thanks in advance |
| Author: | HOTSAUCE170 [ Thu Jun 23, 2016 7:33 pm ] |
| Post subject: | Re: Floor removal |
Post up a pic I'm good at takin shit apart! Sent from denda this |
| Author: | va_quack_smacker [ Fri Jun 24, 2016 7:29 am ] |
okay i will have to post a picture tomorrow, i am at work and work 24hr shifts |
| Author: | ibfishinb [ Fri Jun 24, 2016 8:13 am ] |
Is the floor riveted, crimped, or welded in? Sent from my SM-G920V using Tapatalk |
| Author: | va_quack_smacker [ Fri Jun 24, 2016 9:12 am ] |
the floor is riveted in and the side panels are riveted at the middle and bottom and welded at the top in three spots. i tried to drill the rivets out in one of the side panels but am having a hard time drilling them out compared to other rivets that i have done in the past |
| Author: | BERNIE255 [ Fri Jun 24, 2016 10:10 am ] |
Use a grinder Sent from my iPhone using Tapatalk |
| Author: | msm8281 [ Fri Jun 24, 2016 11:34 am ] |
Get a new bit. Sent from my SAMSUNG-SM-G925A using Tapatalk |
| Author: | ibfishinb [ Fri Jun 24, 2016 1:06 pm ] |
What msm said. Your bit must be dull. Drilling them out should be quick and easy. Then hit the welds with a grinder. Sent from my SM-G920V using Tapatalk |
| Author: | va_quack_smacker [ Fri Jun 24, 2016 1:07 pm ] |
the bit set i have it new, the problem is these rivets still have part of the shaft sticking out that normally breaks off and leaves the indent |
| Author: | Roostertail3 [ Fri Jun 24, 2016 1:25 pm ] |
Tip them with a punch then drill it out. They aren't hard to drill out until you break a bit off in one so be careful. |
| Author: | ibfishinb [ Fri Jun 24, 2016 2:48 pm ] |
What rooster said. I had to do that with a few. If that doesn't work (which it should) hit them with the grinder. Sent from my SM-G920V using Tapatalk |
| Author: | Buzz Killington [ Tue Jul 26, 2016 5:20 pm ] |
Ever do this? Pics? Support the troops. We support you. B. MacDonald |
| Author: | va_quack_smacker [ Tue Jul 26, 2016 9:21 pm ] |
No with work and family stuff I never got around to pulling it. I will more than likely do it after this season ends |
