It is currently Tue Mar 17, 2026 11:26 pm
Reply to topic  [ 7 posts ]
 35hp bog hog surface drive
Post 35hp bog hog surface drive
found one these motors online ans was wondering if anyone has any experience with them or know if they are any good or not
Sun Jul 17, 2016 8:05 pm
Post Re: 35hp bog hog surface drive
On craigslist?
Sun Jul 17, 2016 8:12 pm
yes sir
Sun Jul 17, 2016 8:15 pm
Save your money and get a real mm, you will regret buying it in the long run
Sun Jul 17, 2016 9:01 pm
is it the brackets that arent worth it? i cant afford a new one of the other brands and this one is 2400 with a 35hp vanguard with 10hrs on
Sun Jul 17, 2016 9:19 pm
For that, I'd say go for it as long as you can confirm the Briggs is in good shape, and runs. Start saving so you can replace the frame as soon as you decide you want to, or fix things if needed.
Sun Jul 17, 2016 9:51 pm
Just keep a close eye on the frame and bearings, check welds and make sure everything is tight before taking it out
Sun Jul 17, 2016 11:02 pm
