It is currently Wed Mar 18, 2026 3:54 pm
Reply to topic  [ 11 posts ]
 Problem getting .125 5086 Aluminum
Post Problem getting .125 5086 Aluminum
I know a lot of folks on this forum know boat builders, or build them. I have called all around my area and you would think an easy find but no. I'm looking to make some changes to my 1856 GD (1996) and need 2 pieces 6" X 36" 1/8 thick. I have sheets of 1/8 but not 5086 and since I use it in salt water only I want to go that way. Any suggestions, or leads.
Thanks much, Wayne
Fri Aug 05, 2016 1:19 pm
Post Re: Problem getting .125 5086 Aluminum
Where are you located? That will help with the suggestions.
Fri Aug 05, 2016 2:04 pm
Fri Aug 05, 2016 3:05 pm
Hey, I'm in North jersey. Try r.s. Philips supply. They're a little west but they do carry alot of material.
Fri Aug 05, 2016 6:23 pm
Fri Aug 05, 2016 6:48 pm
I'm sure someone would ship you some.
2015 GatorTrax 1750 /2015 GatorTail GTR35.
Sat Aug 06, 2016 1:36 am
Order from onlinemetals.com or somewhere like that. They're a tad high, but shipping is usually reasonable. There are some other sites that may be a bit cheaper.
Sat Aug 06, 2016 5:00 am
Sat Aug 06, 2016 12:56 pm
Np. They've done me right in the past with a couple orders. Glad it helped.
Sat Aug 06, 2016 1:26 pm
What are you trying to do with it? Close in a tapered transom? If not, You don't need 5086 if you're not doing anything to the bottom of the boat. 5052 is great for anything else and much cheaper.
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Sat Aug 06, 2016 3:54 pm
Sat Aug 06, 2016 6:47 pm
