https://mudmotortalk.com/mmt_v2/
Problem getting .125 5086 Aluminum
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=67771
Author:  11Bravo [ Fri Aug 05, 2016 1:19 pm ]
Post subject:  Problem getting .125 5086 Aluminum
I know a lot of folks on this forum know boat builders, or build them. I have called all around my area and you would think an easy find but no. I'm looking to make some changes to my 1856 GD (1996) and need 2 pieces 6" X 36" 1/8 thick. I have sheets of 1/8 but not 5086 and since I use it in salt water only I want to go that way. Any suggestions, or leads.
Thanks much, Wayne
Author:  reharbert [ Fri Aug 05, 2016 2:04 pm ]
Post subject:  Re: Problem getting .125 5086 Aluminum
Where are you located? That will help with the suggestions.
Author:  11Bravo [ Fri Aug 05, 2016 3:05 pm ]
Author:  rob_rides_03 [ Fri Aug 05, 2016 6:23 pm ]
Hey, I'm in North jersey. Try r.s. Philips supply. They're a little west but they do carry alot of material.
Author:  11Bravo [ Fri Aug 05, 2016 6:48 pm ]
Author:  Fooshman [ Sat Aug 06, 2016 1:36 am ]
I'm sure someone would ship you some.
Author:  Russ [ Sat Aug 06, 2016 5:00 am ]
Order from onlinemetals.com or somewhere like that. They're a tad high, but shipping is usually reasonable. There are some other sites that may be a bit cheaper.
Author:  11Bravo [ Sat Aug 06, 2016 12:56 pm ]
Author:  Russ [ Sat Aug 06, 2016 1:26 pm ]
Np. They've done me right in the past with a couple orders. Glad it helped.
Author:  willett [ Sat Aug 06, 2016 3:54 pm ]
What are you trying to do with it? Close in a tapered transom? If not, You don't need 5086 if you're not doing anything to the bottom of the boat. 5052 is great for anything else and much cheaper.
Author:  11Bravo [ Sat Aug 06, 2016 6:47 pm ]
