It is currently Wed Mar 18, 2026 3:53 pm
[ 7 posts ] |
stereo/trim wiring question
redfisher3
Joined: Tue Jul 22, 2014 6:24 pm Posts: 194 Location: SE Louisiana
I just converted my tiller GTR to console. I noticed yesterday that when I trim up or down, there is some feedback over the speakers. Any clue what it could be??
_________________ 2015 1854 Prodigy Evolve Side Console 37 GTR
| Fri Aug 12, 2016 3:00 pm |
cb5331
 Re: stereo/trim wiring question
What kind of feedback? Popping or whine?
| Fri Aug 12, 2016 4:54 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
| Fri Aug 12, 2016 5:47 pm |
redfisher3
It's a pop any time I mess with the trim. I am running a wetsuits stealth 6 along with 4 infinity 6.5 pushed by a kenwood amp. It never did it before the conversion.
| Fri Aug 12, 2016 6:02 pm |
cb5331
I would think it's a voltage issue. Know how to work a dmm? Put a volt meter across the power and ground on the radio and watch what happens when you cycle the trim. My guess would be that you are sharing a wire now that you weren't before, and when you cycle the trim the voltage drops, the radio kinda shuts off and back on even though it may not look like it.
| Fri Aug 12, 2016 6:45 pm |
redfisher3
Sounds like that could be it. The trim used to be connected on the engine, now it is hooked directly to the battery. Any easy remedy?
| Fri Aug 12, 2016 6:51 pm |
cb5331
Run heavier power wire, run a dedicated power and ground just for the stereo, do what you can to isolate anything to do with the radio from anything to do with the trim.
If you could verify what the voltage drop is, that may help. You may need heavier wiring for the trim and other accessories at the console. If you can verify a drop under the console, and confirm that there isn't actually a drop at the battery, heavier wiring should cure it. If you're getting a drop at the battery as well, then it may take more to fix it.
| Fri Aug 12, 2016 7:33 pm |
[ 7 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 1 guest |
