It is currently Tue Mar 17, 2026 5:07 pm
Reply to topic  [ 10 posts ]
 Gator Trax 1862 questions?
Post Gator Trax 1862 questions?
Ok guys long time reader haven't really posted much on MMT. Just curious I have a 2010 PD36 stage 1 and am looking at a gator Trax 1862. Is that too much boat to push with my motor?. I have tried searching but haven't really found what I'm looking for.
Mon Sep 19, 2016 8:27 am
Post Re: Gator Trax 1862 questions?
Won't break speed records, but would push it fine.
Mon Sep 19, 2016 9:03 am
Just looking to get 3-4 guys to the blind. Maybe 24-25 mph if I'm lucky?
Mon Sep 19, 2016 9:47 am
Should be close to that. You or someone else can correct me as I'm likely wrong, but that should be a gen 2? Should be similar enough to an efi pd with the new lower. Somewhere around 20 with 4 and gear, 24+ with 3, maybe 28 or so best speeds solo or with 2. It'll probably carry a load better than I'm suggesting above, but set expectations low, then you'll be happy lol
Mon Sep 19, 2016 10:01 am
Yes correct a gen 2
Mon Sep 19, 2016 10:50 am
Not going to work very well. I have a 36pd on a 1662(was a 3 man gatothide). It's taken efi heads and prop work to get 3 guys and a hunting load on plane. It will now but only runs about 20mph...
Give Kent at Gator Trax a call. He'll probably tell you he wouldn't sell you that combo even if you wanted it....
Tue Sep 20, 2016 6:35 am
Longer boat would help.^^
Tue Sep 20, 2016 9:03 am
Tue Sep 20, 2016 3:17 pm
How thick is the hull? It's probably a heavier boat so I would think a stock motor you will probably be 25 solo. It should carry a load pretty good being so wide but that is an awefull big boat for a stock 37. My stock 37 HDR on a 1854 runs 27-28 solo 22 with three people of that helps.
Tue Sep 20, 2016 3:38 pm
The guy that is selling it was wrong. It's a 1854.. Not sure if we was measuring to the outside of the chine or what. But it clearly states on the side of the boat 1854
Tue Sep 20, 2016 4:34 pm
