| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| Winch post bow stop question https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=68429 |
| Author: | fjreinke [ Wed Sep 28, 2016 9:23 am ] |
| Post subject: | Winch post bow stop question |
I'm building a trailer for a new hull. I got a 1860 from Uncle J. It's a full flat with a square pipe bow. I'm needing ideas on how to build the winch post and bow stop. Is there a roller that works good on a flat? I'm new to the form but have been creeping for a while and find it very helpful. I have got a lot good info from here. Thanks in advance for any info or pics y'all would like to share. Sent from my iPhone using Tapatalk |
| Author: | Russ [ Wed Sep 28, 2016 10:22 am ] |
| Post subject: | Re: Winch post bow stop question |
Don't bother with a roller. Use a 2x6 or 2x8, put some carpet, make sure the angle is right for your boat, and build the winch post to pull the boat so it rests on/against that. |
| Author: | fjreinke [ Wed Sep 28, 2016 10:33 am ] |
| Author: | Russ [ Wed Sep 28, 2016 10:45 am ] |
Np. If you need any pics, I can take a couple when I get home. |
| Author: | Melnmo [ Wed Sep 28, 2016 3:31 pm ] |
My bow stop was smashed and bent when I bought the boat so I ended up rebuilding it. I cut the old one off where it was bent and simply re-welded some 3/8" thick angle in it's place. The end of the angle support was cut off at the same angle as the bow and an aluminum plate was welded on for a nice landing surface. I put a chunk of horse-mat for cushion and all is well. I don't think this one is going to bend as easily as the original did. . |
| Author: | fjreinke [ Thu Sep 29, 2016 5:55 pm ] |
| Author: | North LA Hunter [ Thu Sep 29, 2016 7:09 pm ] |
I've built 3 or 4 trailers like this and seems to do well. Easy to build and doesn't take a lot of time. Sent from my iPhone using Tapatalk |
| Author: | fjreinke [ Fri Sep 30, 2016 12:58 pm ] |
| Author: | fjreinke [ Fri Sep 30, 2016 1:01 pm ] |
| Author: | North LA Hunter [ Fri Sep 30, 2016 1:59 pm ] |
| Author: | fjreinke [ Thu Nov 24, 2016 5:14 pm ] |
I finished my trailer a while back and never posted a pic so here it is. It works good and is secure. I need to add a safety lanyard incase the winch strap snaps. Thanks to North LA Hunter for sharing his method. Sent from my iPhone using Tapatalk |
