| MudmotorTalk.com https://mudmotortalk.com/mmt_v2/ |
| Linex inside of boat is this OK?? https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=68648 |
| Author: | kawriverfowler [ Sun Oct 16, 2016 8:22 am ] |
| Post subject: | Linex inside of boat is this OK?? |
I have 2 young boys that hunt with me and the inside of my boat is extremely slick of course when wet and muddy. Do you boys see any reason why it would hurt my boat to linex the inside of it??? Please all advice is welcome!!!!! |
| Author: | HOTSAUCE170 [ Sun Oct 16, 2016 8:41 am ] |
| Post subject: | Re: Linex inside of boat is this OK?? |
I wouldn't put truck bedliner in any boat I own cause its a pain in the ass to get out If you ever wanted something different. get a few sheets of hydroturf or some no slip adhesive strips to hold you over if hydroturf is out of the budget right now. you can also use the anti fatigue foam mats too |
| Author: | kawriverfowler [ Sun Oct 16, 2016 8:46 am ] |
Ok thanks for the ideas. But other than your thoughts on why you wouldn't do it, I want to know if this would harm or affect the boat in any ways?? |
| Author: | HOTSAUCE170 [ Sun Oct 16, 2016 9:21 am ] |
| Author: | Bigbend [ Sun Oct 16, 2016 1:52 pm ] |
I bowfished out of a boat that had it in the inside. Owner of the boat said the guy that sprayed it in was pretty particular on prep work. The boat had to be clean aluminum or they wouldn't warranty it. You may want to check with the sprayer beforehand. I wouldn't do the DIY bedliner either, I've seen plenty of those look like shit after a couple outings. I'd also rather fall on EVA foam then linex. |
| Author: | huck Finn [ Sun Oct 16, 2016 2:23 pm ] |
War eagle boat I had , came with that sprayed in , it flaked . H Finn |
| Author: | 4Cody4 [ Sun Oct 16, 2016 6:43 pm ] |
I got a boat sprayed and it peeled off twice. Sent from my iPhone using Tapatalk |
| Author: | kawriverfowler [ Sun Oct 16, 2016 7:46 pm ] |
Thanks boys for all the advice. Much appreciated!!!! |
| Author: | koda4u [ Sun Oct 16, 2016 8:00 pm ] |
Hydroturf. |
| Author: | duck_watcher12 [ Sun Oct 16, 2016 9:17 pm ] |
I sprayed my old boat with it and after 1 season it was peeled off pretty bad. I also went to the lengths to use acid on the aluminum to clean it. In my opinion it's not worth the time money or trouble. |
| Author: | KJH [ Wed Oct 26, 2016 7:17 am ] |
I had it and it was OK... it flaked a little, but not much. I think it added a lot of weight. In the right circumstances, I'd do it again on a boat, but probably not on a mudboat. I did see an older Lund riveted fishing boat that a guy "fixed up". It turned out sweet and the inside was completely sprayed with liner. |
| Author: | J_Ho [ Wed Oct 26, 2016 9:59 am ] |
It peels and gets very hot in the sun. Hydroturf is the bees knees. Period. Don't do it! Sent from my iPhone using Tapatalk |
| Author: | meterman3 [ Wed Oct 26, 2016 10:14 am ] |
I wouldn't do hydro turf either Sent from my iPhone using Tapatalk Pro |
| Author: | brickgw [ Wed Oct 26, 2016 12:33 pm ] |
| Author: | J_Ho [ Wed Oct 26, 2016 1:41 pm ] |
My post was misread. I would do hydro turf over line x. No question. It doesn't get hot, doesn't peel, and the list goes on. Sent from my iPhone using Tapatalk |
| Author: | brickgw [ Wed Oct 26, 2016 4:38 pm ] |
Gotcha |
| Author: | meterman3 [ Sat Oct 29, 2016 10:38 pm ] |
About every 1.5 years I have to replace mine green straight cut grove Sent from my iPhone using Tapatalk Pro |
| Author: | kawriverfowler [ Mon Oct 31, 2016 8:39 pm ] |
I did get it linex and they gave me 100% full warranty! |
