It is currently Fri Mar 20, 2026 4:12 am
Reply to topic  [ 16 posts ]
 RIBBIT.....GG
Post RIBBIT.....GG
How much does a half gal GG weigh? Just wondering how much weight it will add to my boat. Do yall think half gal is enough for a 16x40 with a few dents tht need to be filled in as well? Does it do pretty good for small cracks? I have a few small cracks in the bottom that leak.
Fri Jan 13, 2017 5:50 pm
Post Re: RIBBIT.....GG
Weighs about 44lbs wet, 38 dry.... I'm assuming you haven't dug through the dozens of threads on this topic. It doesn't fill dents well and I wouldn't recommend it for repairing leaks.
-Custom pool noodle
-stage 4 water wings
Fri Jan 13, 2017 5:56 pm
Its just a few hair cracks that drip their not bad. Hell i could probably jb weld them sand and apply gg wouldnt you think? Im not to worried about the dents would be nice to fill them in some. Do you think i could get away witb a quart of gb on a 16x40 then use hald gal g4?
Fri Jan 13, 2017 6:21 pm
G4 is the base , ,G2 is the slicker finish , a quart is plenty 4-5 coats worth.
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Fri Jan 13, 2017 6:32 pm
According to the website g2 is slicker and g4 is more abrasion resistant and gator base is the base
Fri Jan 13, 2017 8:58 pm
You are correct , I knew the g2 was the slicker of the two .
H Finn
BACKWATER PROSTAFF
Fri Jan 13, 2017 9:38 pm
Yea i would rather it be more abrasion resistant im sure its plenty slick enough for my needs
Fri Jan 13, 2017 9:59 pm
http://www.gatorglide.com/
gatorheads@comcast.net
Sat Jan 14, 2017 1:20 pm
How many coats will a quart of gb and g2 get me? Thanks frog
Sat Jan 14, 2017 8:58 pm
You may be in the wrong sport if you are concerned with the weight of a paint-like coating.
Read his website, it has GREAT information. Frog will also talk your ear off if you give him the chance. If you have any questions, call him or ask here. He knows his produc.t
Mon Jan 16, 2017 6:50 am
Mon Jan 16, 2017 7:33 am
Thanks frog and to reharbert it was simply a question i was curious how much it weighed never used it wasnt sure if it was heavier like a bedliner material or more like paint thanks for the advice though ill have to take that into consideration.....
Mon Jan 16, 2017 1:14 pm
That kit is perfect frog thanks for the REAL advice. Retardbert i appreciate the advice to dont want to leave you out buddy....
Mon Jan 16, 2017 1:17 pm
And trust me every bit counts when your coming out on the intercoastal with all the tugs and crew boats with around 20 sacks of crawfish in a 16.5x40 skiff
Mon Jan 16, 2017 1:21 pm
Tue Jan 17, 2017 9:37 am
Yep and i was more curious than anything knew it couldnt weigh a whole lot. He may have been joking i dont know doesnt bother me theres quite a few people on here who cant help but make ignorant comments instead of helping someone out. Maybe they have no life who kniws. I have been on here since 2012 i have seen my fair share of ignorance
. I got my answer though thanks.
Tue Jan 17, 2017 1:59 pm
