It is currently Sun Mar 22, 2026 4:36 am
Reply to topic  [ 30 posts ]
 Need to put something on trailer guides to help boat slide
Post Need to put something on trailer guides to help boat slide
I need to put something on my trailer guides to help the boat slide easier on and off. What do you guys recommend? Rollers the only way to go?
Wed Nov 02, 2016 10:51 am
Post Re: Need to put something on trailer guides to help boat sli
Paint wood with oilbase paint then spay it with pam or silocon spray before load boat.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Wed Nov 02, 2016 10:58 am
Thats your cheapest option or get gator glide.
Wed Nov 02, 2016 10:59 am
Gator glide and be done with it
Wed Nov 02, 2016 6:44 pm
^^^^^This. Gator Glide.^^^^^
Wed Nov 02, 2016 6:52 pm
There's a thread floating around somewhere on here where this dumbass put rain gutters over his bunks. Worked pretty damn good and was cheap though. :lol:
Thu Nov 03, 2016 4:16 am
I went to home Depot and bought a half sheet of starboard and a bunch of #10 stainless screws. Then Cut the starboard into strips, drilled and countersunk screw holes, routed the edges. Boat slides right off.
Thu Nov 03, 2016 6:09 am
I had to buy new bunks that came with carpet, went ahead and put the slick pads over that, my steelflexed hull really slides quick now off/on, have to be careful to keep it clipped on the trailer when backing down, now only the ends of the bunks get wet. Much easier to crank it back on too. I just check that the screws holding down the pads are seated down. Cost for pads was $30.
Fri Nov 04, 2016 3:27 am
What pads did you use? I need to redo all my bunks
I gave up mud motors
Fri Nov 04, 2016 4:43 am
I'm going to use one of those white 4x4 pvc fence posts and rip it in half, one half for each bunk.
Fri Nov 04, 2016 5:07 am
They were the EZ slide pads...figure if they last a couple of seasons, they were well worth it! No more straining to push off a fully loaded duck boat. :mrgreen:
Fri Nov 04, 2016 7:48 am
Has anyone ever tried these? Is this cheap to cheap?
http://www.overtons.com/modperl/product ... h&i=908235
Fri Nov 04, 2016 7:54 am
I understand that Gator Glide is probably the best way to go, but I don't have time to disassemble my boat and flip it right now. Sooooo do I put slides on my bunks or put rollers on my trailer? Gator Glide will have to wait tell off season.
Fri Nov 04, 2016 8:02 am
Fri Nov 04, 2016 9:40 am
Slides
Fri Nov 04, 2016 9:46 am
For you guys that have put gg on your bunks. Did you use treated or untreated lumber?
1850 & 36pd
Sat Nov 05, 2016 9:29 am
Sat Nov 05, 2016 9:32 am
Just put the fuggin rain gutters on that bitch.
Sat Nov 05, 2016 6:04 pm
If you have a used restaurant supply nearby you can usually get 3/4 large used cutting boards I used them before I put steel flex on my boat they are super slick :) :) :) mount them with SS countersunk trim screws
Sun Nov 06, 2016 2:57 am
Found the pics
Sun Nov 06, 2016 3:00 am
Sun Nov 06, 2016 11:05 am
Cut the 4x4 PVC today and screwed them down w SS screws.
Beveled the leading edge a little and look great.
an 8' one cost 24 bucks at lowes and does both bunks
Sun Nov 06, 2016 6:35 pm
Sun Nov 06, 2016 6:40 pm
I slice strips out of old drop-in pick-up bedliners. Stainless screws through the valley between the ridges hold the strips to the bunks. I get the old bedliners from an outfit that removes them to do spray-in liners. Really slick and inexpensive.
Mon Nov 07, 2016 2:13 am
That is a great idea there Stu.
Mon Nov 07, 2016 6:15 am
http://www.gatorglide.com/
gatorheads@comcast.net
Mon Nov 07, 2016 9:52 am
The bedliner strips along with GG make my 24 X 60 a snap to load and unload. I routinely do it alone and I'm 76.
Mon Nov 07, 2016 5:07 pm
Get the composite cap boards and #10 Stainless screws. Drill and counter sink. I back the trailer into the water and then the boat slides right off. It cost 50.00 and some change for the composite capping and screws.
2009 Gator Trax -Gator Hide with Mud Buddy 45 HD Sport
Thu Nov 10, 2016 7:48 am
1850 & 36pd
Thu Nov 10, 2016 10:30 am
Sent from my SAMSUNG-SM-G930A using Tapatalk
1848 GTB, 36 PD w/ FPR
Fri Nov 11, 2016 2:48 pm
