It is currently Tue Mar 17, 2026 2:18 pm
Reply to topic  [ 6 posts ]
 Keep this plywood on transom?
Post Keep this plywood on transom?
Ordered my first mud motor - a 25efi Prodrive /w reverse. It should be here this week. On my transom there is currently a square of plywood - it appears it's riveted in. Should this be removed to mount my motor?
2016 Prodrive X 1848 37efi
Mon Nov 07, 2016 11:32 am
Post Re: Keep this plywood on transom?
First impression would be no - don't remove it. Did you install the wood? It might be there to help strengthen it up for reasons unbeknownst to you.
If might be a good idea to remove it and beef it up correctly.
Pull it off and have a look. Get more photos. You can always put it back.
Mon Nov 07, 2016 1:32 pm
remove wood, beef with aluminum channel and square tubing (the right way)
Mon Nov 07, 2016 4:12 pm
get rid of the wood and get a welder to beef up the transom and put braces on the corners. u will break that transom, just a matter of time.
Mon Nov 07, 2016 8:02 pm
Take it out and put some aluminum there.
The wood holds water that will end up rotting the aluminum eventually.
Mon Nov 07, 2016 8:04 pm
Yeah...ive rebuilt a wood transom and it sucks. Better to just do it right the first time if possible.
Mon Nov 07, 2016 8:13 pm
