| GT 1754 extreme front storage not so dry storage https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=68851 |
| Author: | LA OUTLAW [ Sat Nov 05, 2016 4:05 pm ] |
| Post subject: | GT 1754 extreme front storage not so dry storage |
Any GTB owners having issues with the front storage leaking through the hatch and water coming under the bulkhead???? If so was it fixed by GT? |
| Author: | Richard in LA [ Sat Nov 05, 2016 7:51 pm ] |
| Post subject: | Re: GT 1754 extreme front storage not so dry storage |
Most of these types of boats are constructed similarly, and you won't ever have complete dry storage up front. Mine will also get water up there |
| Author: | LA OUTLAW [ Sun Nov 06, 2016 12:41 am ] |
Thanks |
| Author: | gurt2140 [ Mon Nov 07, 2016 9:11 am ] |
I have the same problem. Any little bit of debris will clog the drain hole up. If i keep the debris out it will stay dry unless its out in a hard rain. |
| Author: | jayrod075 [ Tue Jan 03, 2017 5:50 pm ] |
Same problem here... my life jackets smell terrible now because it gets wet in there. |
| Author: | CJB [ Wed Jan 04, 2017 9:52 am ] |
It'll get wet...I would take my life jackets out anytime the boat got wet and hang them to dry before the next trip out to keep them from getting that stank.. |
| Author: | 911gsxr [ Fri Jan 06, 2017 5:51 am ] |
I put weather strip around the lid on mines! Worked great |
| Author: | ibfishinb [ Fri Jan 06, 2017 7:57 am ] |
My drain tube is alays plugging up. So I now open my bow storage and put a box fan over it to circulate air and dry things out. Sent from my SM-G920V using Tapatalk |
| Author: | Russ [ Fri Jan 06, 2017 10:43 am ] |
I've got a bilge fan under my extended deck that sucks air out of the front storage. A couple small holes drilled on the other side low and high for an inlet to circulate fresh air through the box. I only run it when the humidity is less than what's in the storage area. |
| Author: | ibfishinb [ Fri Jan 06, 2017 2:31 pm ] |
Good idea Russ. Not sure if they make a 12v humidistat, but that would be nice to have. Sent from my SM-G920V using Tapatalk |
