| Keep this plywood on transom? https://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=68865 |
| Author: | Exbellicus [ Mon Nov 07, 2016 11:32 am ] |
| Post subject: | Keep this plywood on transom? |
Ordered my first mud motor - a 25efi Prodrive /w reverse. It should be here this week. On my transom there is currently a square of plywood - it appears it's riveted in. Should this be removed to mount my motor? |
| Author: | reharbert [ Mon Nov 07, 2016 1:32 pm ] |
| Post subject: | Re: Keep this plywood on transom? |
First impression would be no - don't remove it. Did you install the wood? It might be there to help strengthen it up for reasons unbeknownst to you. If might be a good idea to remove it and beef it up correctly. Pull it off and have a look. Get more photos. You can always put it back. |
| Author: | Buckmark311 [ Mon Nov 07, 2016 4:12 pm ] |
remove wood, beef with aluminum channel and square tubing (the right way) |
| Author: | dead animal [ Mon Nov 07, 2016 8:02 pm ] |
get rid of the wood and get a welder to beef up the transom and put braces on the corners. u will break that transom, just a matter of time. |
| Author: | North LA Hunter [ Mon Nov 07, 2016 8:04 pm ] |
Take it out and put some aluminum there. The wood holds water that will end up rotting the aluminum eventually. Sent from my iPhone using Tapatalk |
| Author: | brickgw [ Mon Nov 07, 2016 8:13 pm ] |
Yeah...ive rebuilt a wood transom and it sucks. Better to just do it right the first time if possible. |
