It is currently Thu Mar 19, 2026 1:57 pm
Reply to topic  [ 10 posts ]
 Help
Post Help
I am new to the site and im looking foward to getting a motor for my boat i had one build by lynn at extreme metal fab . It a tank and im hearing that if i wanted a mud motor i would need two . Just wanted some thoughts its a 20/60 all 3/16 with 1/8 sub floor 4 ft front deck 3ft floating deck and a 20in hunt deck. Like i said a tank. Thanks for any info and also some guessed speeds at top end
Tue Nov 29, 2016 3:28 pm
Post Re: Help
What i ment to ask if if their is a mud motor that can push a boat like mine i need a single motor but i think i have to much boat
Tue Nov 29, 2016 5:55 pm
Post Re: Help
It can be done. Figure on cost of a motor (8 grand or so), then another 3-5k for mods, plus some prop work. Bayou surface drives, Texas mud motors, delta performance should all be able to help you figure out what you ought to do for mods. There's a few of us here that can help you do it yourself if you want to turn your own wrench and stick with a carbed motor.
Tue Nov 29, 2016 6:59 pm
Post Re: Help
Where you located? I've got a bit of a beast we can put on your boat for a test run to let you see what to expect, and if you need to go further than I did.
Tue Nov 29, 2016 7:00 pm
Post Re: Help
Don't let Russ hang that starter eating time-bomb on your hull :lol:
For real though... It would be good for informational purposes, despite its appetite for starters...
-Custom pool noodle
-stage 4 water wings
Tue Nov 29, 2016 7:18 pm
Post Re: Help
Baaahahahaha
Tue Nov 29, 2016 7:48 pm
Post Re: Help
I am running similar to what you described right now. Mine is a 20x60 CC 3/16 bottom 1/8 sides and .100 sub floor and 2 7ft rod boxes, 2 rear compartments, 22 gal tank and a 6ft front deck. I'm running 1 motor for now until I can get duals. I have a gen 3 prodrive with a stage 2 done by Jamie. Empty boat I run 26mph. 2 man hunting load 23mph. 3 man hunting load 18mph. 4 man hunting load/w 2dogs 13mph all deep water speeds. If I can find shallow water I have seen 22mph with 4 man hunt load hope this gives you an idea
Sent from my SAMSUNG-SM-G890A using Tapatalk
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Tue Nov 29, 2016 8:08 pm
Post Re: Help
Im in denham springs . I have an outboard on it now still have yet to put it in the water trying to get this motor going it was my dads and its old
Wed Nov 30, 2016 7:08 am
Post Re: Help
Team marsh... thanks for the info i think i might have to stay with an outboard until i can get duals and a new transom
Wed Nov 30, 2016 6:35 pm
Post Re: Help
K. I've got a friend in walker that's wanting to try my motor on his boat. When I send or bring it down to him, you're welcome to try it as well, or go for a ride with us. His is 20.5 with a 54" bottom, so it'll give you an idea.
Wed Nov 30, 2016 7:03 pm
