It is currently Thu Mar 19, 2026 4:28 am
Reply to topic  [ 12 posts ]
 Winch post bow stop question
Post Winch post bow stop question
I'm building a trailer for a new hull. I got a 1860 from Uncle J. It's a full flat with a square pipe bow.
I'm needing ideas on how to build the winch post and bow stop. Is there a roller that works good on a flat?
I'm new to the form but have been creeping for a while and find it very helpful. I have got a lot good info from here.
Thanks in advance for any info or pics y'all would like to share.
Wed Sep 28, 2016 9:23 am
Post Re: Winch post bow stop question
Don't bother with a roller. Use a 2x6 or 2x8, put some carpet, make sure the angle is right for your boat, and build the winch post to pull the boat so it rests on/against that.
Wed Sep 28, 2016 10:22 am
Wed Sep 28, 2016 10:33 am
Np. If you need any pics, I can take a couple when I get home.
Wed Sep 28, 2016 10:45 am
My bow stop was smashed and bent when I bought the boat so I ended up rebuilding it. I cut the old one off where it was bent and simply re-welded some 3/8" thick angle in it's place. The end of the angle support was cut off at the same angle as the bow and an aluminum plate was welded on for a nice landing surface. I put a chunk of horse-mat for cushion and all is well. I don't think this one is going to bend as easily as the original did.
Wed Sep 28, 2016 3:31 pm
Thu Sep 29, 2016 5:55 pm
I've built 3 or 4 trailers like this and seems to do well. Easy to build and doesn't take a lot of time.
Thu Sep 29, 2016 7:09 pm
Fri Sep 30, 2016 12:58 pm
Fri Sep 30, 2016 1:01 pm
Fri Sep 30, 2016 1:59 pm
I finished my trailer a while back and never posted a pic so here it is. It works good and is secure. I need to add a safety lanyard incase the winch strap snaps. Thanks to North LA Hunter for sharing his method.
Thu Nov 24, 2016 5:14 pm
cron
